What Kind Of Thinset Mortar To Use For Installing Slate On Top Of Aggregate? - Flooring - DIY Chatroom Home Improvement Forum
Old 09-19-2010, 01:59 PM   #1
What kind of thinset mortar to use for installing slate on top of aggregate?
We have a concrete (aggregate) front porch, and I'd like to install slate tiles on top of it. I'd read that you need a special type or mortar(thinset) when adhering stone to a stone substrate. Does anyone know what kind of mortar/thinset I'll need to use for this project?
Thanks in advance!
TitaniumVT is offline   Reply With Quote
Old 09-19-2010, 03:37 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If you are talking about a concrete with an expossed aggregate surface, any modified thinset will work. It would be better however in my opinion for you to use unmodified thinset but to modify it using your own additive rather than water. For example: Mapei's Kerabond thinset mixed with Mapei's Keralastic additive. There are others.
If your surface is an epoxy-aggregate surface, the old surface should be removed totally.
XXX
Old 09-20-2010, 02:09 AM   #3
Thanks very much for the insight, Bud. Yes, I'm talking about a concrete patio with exposed aggregate. I'll do as you suggest and try an unmodified thinset. Thanks!
Old 09-20-2010, 08:33 AM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Don't forget...the unmodified thinset in this case MUST be mixed with the proper additive, not water.
XXX
What is the correct ratio of thinset mortar to water? tripower Flooring 15 09-26-2012 07:39 AM
Applying thinset over sealed slate? SeriousShar Flooring 0 02-26-2010 11:24 AM
Cultured Stone - Mortar or Thinset? JackOfAllTrades Building & Construction 6 11-03-2009 04:55 AM
how to remove mortar glue residue on slate tiles aggiejess7 Flooring 5 05-13-2009 05:00 PM
Ideas for getting up slate thinset mbur113 Remodeling 2 09-15-2006 10:35 PM
