What Kind Of Laminate Should I Go With? - Flooring - DIY Chatroom Home Improvement Forum
Old 09-13-2010, 06:43 AM   #1
What kind of laminate should I go with?
Hello, I am wondering what kind of laminate all of you diy-ers would suggest? I have children and pets and need something that is pretty durable. This will be my 2nd time installing laminate and I would like to upgrade our Costco laminate. I am interested in Shaw and Vainer but, am open to suggestions. Anyone with any problems, tips, or advice with their own personal experience would also be GREATLY appreciated. Thank you
diy2010 is offline   Reply With Quote
Old 09-13-2010, 12:58 PM   #2
ADCO Flooring
If you wont something durable i would go with 12 mm laminate flooring
ADCO Hardwood & Mouldings
ADCO Flooring is offline   Reply With Quote
Old 09-14-2010, 05:54 AM   #3
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
The thickness of the laminate has nothing to do with durability. I'd check out Wilsonart. They are shutting down their laminate division and offering huge discounts with all warranties intact for the next few months. Wilsonart Red Label has one of the best wear layers out there. It's more like countertop laminate than normal laminate flooring. Much much thicker wear layer.
poppameth is offline   Reply With Quote
Old 09-14-2010, 09:56 AM   #4
floor_whore
Send a message via Yahoo to Aaroncarpet
The only way to tell is to take home samples and scratch them with a screwdriver and see which one is hardest to scratch...thickness isn't as important as the quality, sheen, and durability of the finish layer....
A hundred yards a day (residential), keeps the bill collectors away....
Aaroncarpet is offline   Reply With Quote
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
countertops-to tile or relaminate? mudpaw Remodeling 11 10-02-2011 09:43 AM
Can't decide: Laminate or Engineered? rogersmj Flooring 7 08-30-2009 08:10 AM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 12:04 AM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
