What Is On This HW Floor And How Can I Fix It? - Flooring - DIY Chatroom Home Improvement Forum
Old 04-11-2014, 06:03 PM   #1
Rewards Points: 95
What is on this HW floor and how can I fix it?
I just bought this fixer-upper house as a rental. Can you tell what is on this antique floor? It's flaking off in very thin chips. I don't want to sand it because it looks like it's been sanded a couple of times before from the dip you can see near the edges.
I would like to recoat it with some "miracle" stuff that will melt whatever's on there now and recoat all in one coat! Does "miracle" stuff exist?
I can't put poly over it because there are so many chips coming off. I read somewhere that if it's shellac, ammonia will melt and "revive" it. Is this true? How could I tell if it's shellac? Help!
Thank you!
IDIMyself is offline   Reply With Quote
Old 04-11-2014, 08:07 PM   #2
firehawkmph's Avatar
Rewards Points: 1,798
Just guessing but it looks like somebody already used a polyurethane finish on it without sanding prior to coating. Poly sits on top and needs to be scuffed even between coats.
Mike Hawkins
firehawkmph is online now   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
MTN REMODEL LLC (04-12-2014)
Old 04-11-2014, 08:16 PM   #3
Rewards Points: 95
can I remove this without sanding?
Can I remove this product without sanding?
Old 04-11-2014, 10:09 PM   #4
Rewards Points: 690
A cabinet scraper and "ELBOW GREASE"
ED
de-nagorg is online now   Reply With Quote
Old 04-12-2014, 06:41 AM   #5
Rewards Points: 95
I would be more than glad to do this but
Should I used some product like paint remover to soften it? When you say cabinet scraper, is this some wide, soft, metal or plastic scraper? The rooms are small so I could easily do it by hand.
thank you!
Old 04-12-2014, 08:17 AM   #6
If you decide to use some kind of stripper to softer the finish, try it on a small spot in the corner in case you don't like the results. If that works, go at it. You'll still have to do some sanding afterwards before applying a new finish. The only problem I would have is putting a lot of effort into it because it's a rental property.
Mike Hawkins
IDIMyself (04-15-2014)
Old 04-12-2014, 10:52 AM   #7
Rewards Points: 690
This is one available at Sears, Many more are available at nearly every hardware store. And a little red devil paint and varnish stripper would help, There is still a minimal amount of sanding needed after the finish is stripped, but a simple orbital sander would suffice.
ED
The Following User Says Thank You to de-nagorg For This Useful Post:
