What/How To Transition From 1: Higher Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 04-27-2010, 10:46 PM   #1
What/How to transition from 1: higher floor
I have a room that the floor is 1" higher than the connecting room.
The high floor will get new vinyl, the lower floor is getting ne carpet.
Is there some type of ramp or way to not have a trip lip?
bjlffire is offline   Reply With Quote
Old 04-27-2010, 11:29 PM   #2
Military Mom of 4
Snav's Avatar
There are a variety of risers, joint bars, lip catches and so on so forth that are made to traverse the different thicknesses of flooring.
The best way to determine what to buy is to go looking - at a big box store (Lowes, Home Depot, Ace) they'll likely have them spread throughout the store in different locations: Sold with the hardwood flooring, sold with carpeting, sold with door jambs and insulation, etc.
However, if you're going to be putting in carpeting and want there to be less than 1" to deal with then I suggest you consider putting in another layer of subfloor - or, when you peel up the old kitchen floor - to figure out why it's higher, maybe you can remove some height there
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
How to anchor toilet flange to porcelain tile? bobmg Plumbing 32 08-19-2013 09:32 PM
Uneven hw floor to vinyl transition joemontana16 Flooring 0 03-10-2010 10:10 AM
hardwood floor transition to tile dcbc Flooring 1 03-14-2009 03:06 PM
Tub to floor transition Richo Plumbing 17 01-18-2008 06:16 AM
Laminate Flooring Transition Question flysndoc Flooring 1 01-29-2007 10:48 PM
