What Flooring Is Best To Use? - Flooring - DIY Chatroom Home Improvement Forum
Old 04-24-2011, 06:34 AM   #1
what flooring is best to use?
I have glued down kitchen carpet and linolium on my floor right now which is 35 years old. It is glued to plyboard flooring. What would be best to use tile or wood floor? I need the easiest fix.
Spencerj is offline   Reply With Quote
Old 04-24-2011, 07:04 AM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
You finished your request with.....need the easiest fix.
You open yourself up to a ton of scrutiny.
Easy fix because of what?
budget?
skill level?
time to flip it?
need to move in?
existing conditions of the floor?
in-laws coming over for Easter Dinner?
tcleve4911 is offline   Reply With Quote
Old 04-24-2011, 07:06 AM   #3
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Wood or tile is used in many a kitchen
Both have to be done properly and both take a lot of skill to do right.
Old 04-24-2011, 07:50 AM   #4
When I bought my house it had hardwood throughout, including the kitchen. It looked really nice. Until a small water leak ruined it. I will never install wood or any other product that has the potential for damage with exposure to wet.
creeper is offline   Reply With Quote
Old 04-24-2011, 07:52 AM   #5
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Floor tiles will crack if water gets to the subfloor.
jus sayin......
Old 04-24-2011, 08:08 AM   #6
O..................Happy Easter!
Old 04-24-2011, 08:10 AM   #7
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Cluck Cluck.....have a nice day.
It's sunny and 50 here in Maine....Happy Easter
BTW...the OP is gone.............
Old 04-24-2011, 08:13 AM   #8
Actually I never thought of that. Suddenly cheezy vinyl is looking a little appealing. At least for my situation- low budget, busy kids and large dog
Old 04-24-2011, 08:20 AM   #9
Hey Mr. Since I have your attention, what do you think of floating click together porcelain. ?
Old 04-24-2011, 08:26 AM   #10
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
I did it on a small bathroom and it was just okay.....
Hard to cut (needed a diamond blade)
I didn't like the "grout" that came with it.
The grout should be sealed but the instructions didn't say anything about sealing...just a tube of caulk/grout....I found it to be porous.
Floating underlayment was easy.
Removed all the baseboard and installed new baseboard on top of the tile. Otherwise a shoe molding is needed.
Not bad though.......
Pretty inexpensive and quick.
The locking can get tricky towards the end.....
Old 04-24-2011, 08:43 AM   #11
Easy to install is very appealing to me. Single mom and DIY newbie. When I read other posts that address floor flex and joist span it all starts to sound like Charlie Brown's teacher. Too much to process at this time. My current damaged hardwood has a layer of vinyl and then 3/4 particleboard as a subfloor so I figured a floating porcelain would eliminate the need for reinforcement, but I thought it was expensive. Maybe just up here?
Central Ontario- finally felt like spring yesterday 22c (72f) Cold again today calling for more and more rain all week Grrr
Flooring for hot tub room with tongue and groove base flooring. tkmiller Flooring 0 10-24-2010 12:21 PM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 08:53 PM
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 09:00 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 11:32 AM
