What Floor Heating System Would You Recomend? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-08-2013, 11:12 AM   #1
What floor heating system would you recomend?
Hi my name is Serge from Canada. It is cold up there in winter. A lot of people looking for reliable and energy efficient floor heating. I found two systems to be nice. One based on carbone film radiant electrical floor heating It is just 1/64" thin and used under hardwood, nailed (!) with the flooring gun. And right at the same page a so called Flat Wire Floor heating. Both are taking about 8-10 watt per 1 SQF of energy. They say usual ones would take about 16 watt for the same effect. I used more to water based systems like on this page . The only problem I see is that I need about 1 1/2" of concrete subfloor for this water based heated floors which is not always possible. Therefor this system dosen't need an electrical power. That is freaking dilemma! Who knows about flat pipe water based floor heating? A can't put cement on my floor and I don't want to pay terrible electrical bill too, what should I do?
SF Stone is offline   Reply With Quote
Old 02-08-2013, 11:16 AM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by SF Stone View Post
I used more to water based systems...
does that mean you have a FHW system now?
what is under the bathroom floor?
or is this all just some thinly veiled newbie advertising spam?
Old 02-08-2013, 12:15 PM   #3
not a spam
Under the tiles they recommend Flat Wire Electrical Floor heating. I used it already, only problem I had I needed to buy a wide-staple gun from Makita ($250) but do not regret it because this gun is perfect for scratch coat math and for other things as well
Old 02-08-2013, 12:16 PM   #4
by the way, what is FHW?
Old 02-08-2013, 12:46 PM   #5
MarginallyQualified
Forced Hot Water aka Hydronic
by the way, what does water based system mean?
Old 02-08-2013, 12:50 PM   #6
Actually I ment Hydronic, sorry
Old 02-08-2013, 04:18 PM   #7
Rewards Points: 13,300
http://www.pexheat.com/Underfloor-Heating
Tags
floor heating
Old low voltage lighting system - switches stopped working. zepman Electrical 14 02-17-2016 08:18 PM
Boiler system not completely filling? jeffro83 HVAC 9 08-31-2012 12:56 PM
Need to bleed a hot water baseboard heating system Brewmaster HVAC 4 02-17-2011 08:04 PM
Need advice RE: purging air from baseboard hot water heating system mikenri HVAC 2 01-19-2011 08:17 PM
Size A/C system properly 70stang HVAC 1 03-26-2006 08:22 PM
