What Final Material Should Be On The Subfloor Before Linoleum? - Flooring - DIY Chatroom Home Improvement Forum
Old 07-18-2008, 09:25 AM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,086
What final material should be on the subfloor before linoleum?
can I easily put linoleum on top of any wood material, or does it have to be a specific type?
Journeyman Plumber
Old 07-18-2008, 10:36 AM   #2
Rewards Points: 2,906
As long as the surface of the material is smooth, you should be able to install linoleum over it.
Some underlayments are better than others because some will swell up and lose their strength if they get wet (like particle board or chipboard), but both are suitable substrates for gluing linoleum down to. You just have to be more careful about not getting the underlayment wet.
Nestor_Kelebay is offline   Reply With Quote
Old 07-19-2008, 05:55 PM   #3
Doing it myself
Alan's Avatar
so you think regular plywood would be OK if the surface is decent?
Journeyman Plumber
Old 07-19-2008, 06:57 PM   #4
Plywood would probably work fine. However, you'd be better off buying a "fir plywood underlayment" instead of fir plywood. The reason why is that plywood is allowed to have open voids on the inside plies which can cause "soft spots" on the floor. With fir plywood underlayment, the voids in the interior plys are filled to prevent those soft spots from occuring.
It makes little difference if you plant to install a soft flexible flooring like linoleum. It's really only important if you plant to install small ceramic tiles.
However, for my money, I would install fir plywood underlayment rather than just fir plywood. But, I wouldn't say that doing so would result in any better or more durable floor installation. It's just extra security against having any potential problems with the floor.
framing material estimate maydoug Building & Construction 38 06-12-2009 01:32 PM
Material to use for replacing linoleum (glued down). spookercat Flooring 2 06-25-2008 11:51 PM
Proper material to raise a subfloor.... Alan Building & Construction 2 06-12-2008 06:29 AM
Linoleum Finish Question scubasteve882001 Flooring 1 02-12-2007 07:55 AM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 07:41 PM
