What Do You Think Of Parquet? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-15-2011, 01:59 AM   #1
What do you think of parquet?
It's in pretty good shape (except for some water damage in the kitchen when the house was in foreclosure/vacant). I know very little about flooring. Is it worth refinishing some day? I'm assuming since it's held up since the 60's it must be decent flooring and durable. What's your opinion on this type of flooring?
Thanks so much!
magoi is offline   Reply With Quote
Old 03-15-2011, 06:13 AM   #2
woodman58's Avatar
It is a floor that lasts a long time. The only problem I know of would be the glue used. The glue tends to break down over the years. The floor may be secured to the floor now. But, when you try to refinish it the weight and power of the sander may start breaking them loose. When your at the point of replacing or refinishing you might try to sand it. You have the same thickness as a 3/4" floor has above the tounge. If it does break up you will have to replace it. All you would be out is the rental price of the sander.
woodman58 is offline   Reply With Quote
Old 03-15-2011, 06:13 AM   #3
DIY staff
Rewards Points: 7,174
If you like the look,it may be worth sanding and refinishing----Many were not thick enough to take sanding,however.
The early parquet was glued--after all these years the glue may be to brittle to take the abuse that a floor sander hands out----it may well pop loose and fail.
There are the facts-----you choose.---Mike----
Refinish/match old parquet or new hardwood? rational Flooring 1 04-29-2011 10:25 PM
Parquet on wood sub-floor removal Bacardiman04 Flooring 3 10-14-2009 10:59 AM
Painting Parquet Floors The Raven Painting 4 07-20-2008 09:21 AM
Want to try to refinish hardwood floors and parquet floors proofer Flooring 11 04-20-2008 05:59 PM
Stripping rubber padding off a parquet floor nubee Flooring 1 04-22-2007 01:08 PM
