Old 12-06-2012, 04:09 PM   #1
What to do with this transition?
What's the general practice for a transition like this? The two pictures are opposite sides of the edge of a bath alcove. I am laying tile and the other room will be carpet. Should I figure for the width of a transition strip or can I just put the transition midway. Should I try to make the transition even with the outer wall edge?
See photo's next post
ees789 is offline   Reply With Quote
Old 12-06-2012, 04:14 PM   #2
I plan on putting my edge where you see the wonderboard edge. Whadya think?
And yes, thats about a 3/8 where the plywood butts the particleboard. Should I fix that gap?
What to do with this transition?-imag0032.jpg   What to do with this transition?-imag0033.jpg
Old 12-06-2012, 04:16 PM   #3
Most people use a marble threshold.
http://www.bing.com/images/search?q=...hold&FORM=IGRE
Old 12-07-2012, 01:36 PM   #4
Yes, but where would you locate it? Should the transition edge line up even with the edge of the wall.
Marble sounds good but this home doesn't require that level of finish. Should I even worry about a strip? The carpet guy can just butt up to it right?
Old 12-08-2012, 10:00 AM   #5
Nothing fancy or expencive about a marble transition. Any Lowes or HD will stock it in the flooring dept.
Yes it comes out even with the walls.
Old 12-09-2012, 03:24 PM   #6
http://www.schluter.com/137.aspx
Dantro is offline   Reply With Quote
Old 12-10-2012, 06:01 PM   #7
Thanks guys but my question is directed more to where the transition should be located in this situation. Am I guessing right, just put it midway down the wall, or should I try and line the edge with the corner? I put the tape measure there so you can specify you're opinion.
Old 12-11-2012, 06:05 AM   #8
Always split the door so to can't see flooring when door Is closed. Obviously with wood, headerboards, you may have some reveal
Old 12-11-2012, 06:08 AM   #9
Ha no doorjam, then it's basically what works and looks best I'd say
Old 12-12-2012, 07:54 PM   #10
Yeah, its about a 5 foot wide opening. Thanks for the input, keep it coming. Where would you put the transition? Line up to the edge, or a few inches back like where I have it?
Old 12-12-2012, 08:00 PM   #11
I would probably go to the edge of the wall.
Awoodfloorguy is offline   Reply With Quote
The Following 2 Users Say Thank You to Awoodfloorguy For This Useful Post:
ees789 (04-01-2013), oh'mike (12-12-2012)
Transition from Vinyl to Wood Question petros151 Flooring 3 02-16-2012 12:42 PM
door jamb cut over transition rtoni Building & Construction 4 10-28-2011 04:50 PM
Transition from hardwood to tile Rroberson Flooring 2 12-23-2010 11:45 PM
Tiling entryway - proper transition for this scenario? Scott99999 Flooring 5 12-22-2009 01:12 AM
Engineered Hardwood: Inlaid transition? SteveSmith98 Flooring 6 03-24-2009 12:21 PM
