-   -   What to do with this transition? (http://www.diychatroom.com/f5/what-do-transition-165760/)
ees789 12-06-2012 04:09 PM
What's the general practice for a transition like this? The two pictures are opposite sides of the edge of a bath alcove. I am laying tile and the other room will be carpet. Should I figure for the width of a transition strip or can I just put the transition midway. Should I try to make the transition even with the outer wall edge?
See photo's next post
ees789 12-06-2012 04:14 PM
photos
2 Attachment(s)
I plan on putting my edge where you see the wonderboard edge. Whadya think?
And yes, thats about a 3/8 where the plywood butts the particleboard. Should I fix that gap?
joecaption 12-06-2012 04:16 PM
Most people use a marble threshold.
http://www.bing.com/images/search?q=...hold&FORM=IGRE
ees789 12-07-2012 01:36 PM
placement
Yes, but where would you locate it? Should the transition edge line up even with the edge of the wall.
Marble sounds good but this home doesn't require that level of finish. Should I even worry about a strip? The carpet guy can just butt up to it right?
joecaption 12-08-2012 10:00 AM
Nothing fancy or expencive about a marble transition. Any Lowes or HD will stock it in the flooring dept.
Yes it comes out even with the walls.
Dantro 12-09-2012 03:24 PM
schluter
http://www.schluter.com/137.aspx
ees789 12-10-2012 06:01 PM
Where?? not what!
Thanks guys but my question is directed more to where the transition should be located in this situation. Am I guessing right, just put it midway down the wall, or should I try and line the edge with the corner? I put the tape measure there so you can specify you're opinion.
Dantro 12-11-2012 06:05 AM
Always split the door so to can't see flooring when door Is closed. Obviously with wood, headerboards, you may have some reveal
Dantro 12-11-2012 06:08 AM
Ha no doorjam, then it's basically what works and looks best I'd say
ees789 12-12-2012 07:54 PM
yup, not a doorway
Yeah, its about a 5 foot wide opening. Thanks for the input, keep it coming. Where would you put the transition? Line up to the edge, or a few inches back like where I have it?
Awoodfloorguy 12-12-2012 08:00 PM
I would probably go to the edge of the wall.
