What To Do With This Subflooring Over Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 07-03-2011, 04:32 PM   #1
DYI Novice
What to do with this subflooring over concrete before lying down Vinyl
Novice here. I have cutout a lil area of carpet by my front door. I want to laydown a vinyl flooring sheet to make it easy to clean since my front door is my main "guest door". I have a concrete slab ranch. On top of the concrete (as pictured) is this subflooring (not sure if thats the right word).
My question is, between each square is a gap that I know I can't just leave it how it is with thin vinyl. What exactly are my options here. I assume that the 2 that I have are filling the gaps with some kinda filler, or removing the squares that are glued on. I'm open to any idea.
Thanks guys
hawks81 is offline   Reply With Quote
Old 07-03-2011, 04:42 PM   #2
looks like grouted tile to me. if you want to leave it you can probably skim over the gaps with a floor patch designed to work over tile to smooth the floor out. the other option is to remove it down to the subfloor which is a lot more work.
The Following User Says Thank You to DannyT For This Useful Post:
hawks81 (07-03-2011)
Old 07-03-2011, 04:46 PM   #3
DYI Novice
Not sure if maybe I left out a detail so please don't be offended if I'm telling you what you already know......
It is tile, but there is no grout. The gaps are not filled at all.
Old 07-03-2011, 05:01 PM   #4
woodman58's Avatar
This is vinyl sheet goods. You can cut the square with a razor and scrape it off the concrete. Or, you can fill the grout areas with a floor leveler.
woodman58 is offline   Reply With Quote
The Following User Says Thank You to woodman58 For This Useful Post:
Old 07-03-2011, 05:40 PM   #5
DYI Novice
Well, less than an hour later...... here is the option I choose.
It was REALLY easy......the adhesive must have been so old, I used a 1 1/2" cold chisel and they popped off in full pieces.
Now to clean whats left. Despite the lines in the picture, it is as smooth as concrete can be. No ridges or anything.
Thanks for the advice.
Old 07-03-2011, 08:34 PM   #6
DYI Novice
Finished DIY project!!
Old 07-04-2011, 06:50 AM   #7
woodman58's Avatar
Sorry, you said it did not have any grout and in the pic it looked like it could be vinyl. Job looks good.
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
House Main Drain Leaking under Concrete Tom738 Plumbing 0 06-01-2010 08:54 AM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 01:03 PM
Garage concrete and driveway asphalt repairs creamaster Building & Construction 4 07-12-2008 11:51 PM
