What Do I Need To Do To Lay Vinyl - Flooring - DIY Chatroom Home Improvement Forum
Old 02-19-2012, 02:30 PM   #1
what do i need to do to lay vinyl
What do I need too do?
I currently have the tung and groove sub floor, what do I need to do lay vinyl flooring?
What type of underlayment do I need?
What is best perimeter or whole floor bonding?
Underlayment nailed or stapled?
Tools needed?
the room is 11'6" x 11'6"
Hardway is offline   Reply With Quote
Old 02-19-2012, 03:39 PM   #2
Rewards Points: 12,812
Is it T &G hardwood flooring, 1 X 6's, plywood, OSB ?
Is the floor nice and flat and solid?
Most often it's just 1/4 subfloor rated sanded plywood for an underlayment.
I use a pneumatic narrow crown staple gun set on automatic with 1-1/4 staples. It needs to be layed so the seams do not line up with the floor joist below. Attached every 4" on the outsides and 6 to 8" in the field.
No glue under it.
DO NOT USE LAUON. Reason being it can cause color bleed through and glue to reliece.
I use staples instead of nails because the staples leave tiny holes that do not need to be filled and also there no hammer dimples.
Once the plywoods in you have to go over all the seams with floor leveler.
Once it's dry go over it with a sander. Once vacuumed your ready for flooring.
I use glue under the whole floor not just the edges. I've seen some of them buckle and wrinkle when things get slid around in the room.
Do not cheap out on the linolium! A good quality one should last 20 years.
Old 02-19-2012, 03:50 PM   #3
No glue under it.
Sorry it is OSB
The floor is flat and solid
Standard 1-1/4 stapler?
what type of floor leveler?
will need a floor sander or will an oribtal sander do the job?
I have 3 rooms same size.
Old 02-19-2012, 04:02 PM   #4
http://www.ridgid.com/Tools/R150FSA-Stapler/index.htm
This is what I use. There not expencive and I can install a 4 X 8 sheet in under 2 min.
Non gypsom floor levler.
If your carefull when applying the floor leveler a simple obital sand will clean it up in seconds.
Old 02-19-2012, 04:03 PM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 12
No glue under it.
Good advice, except for the parts that are wrong.,
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 02-19-2012, 04:13 PM   #6
Then why not correct me instead of teasing us. Always room to learn something new.
Hardway (02-19-2012)
Old 02-19-2012, 04:26 PM   #7
I a 1/4" and 1/2" crown stapler.
Old 02-19-2012, 04:32 PM   #8
1/4" , 1/2 is to wide.
Old 02-19-2012, 04:37 PM   #9
miss typed or stated, I have narrow crown stapler and 1/2" crown stapler.
Old 02-19-2012, 04:42 PM   #10
And if you do not believe a 1/4 staple will hold try a scrap piece of the 1/4 plywood and try to remove it.
Old 02-19-2012, 04:45 PM   #11
I use it to buld bird houses and feeders
Old 02-19-2012, 04:58 PM   #12
Not sure I would use it for outside stuff. May work but I would be afraid they would rust off or leave stains on the outside from the rust.
Old 02-19-2012, 05:15 PM   #13
Rewards Points: 12
Underlayment staples are coated so they won't rust. Otherwise the moisture in the adhesive would cause them to rust.
Old 02-19-2012, 06:40 PM   #14
Rewards Points: 12
Use 7/8" staples. 1 1/4" will blow thru the 1" combined subfloor and you will lose holding power. They should be 4" to 6" in the field and 2" to 3" on the edges. Use only cementious based patch on the seams. Then sand only the seams. You don't use luan because it can have voids in the plys which can collapse. In 40 years I have never seen luan bleed. Use only underlayment plywood.
Old 02-19-2012, 07:00 PM   #15
http://www.askthebuilder.com/260_She..._Errors_.shtml
http://www.handyamerican.com/e-book-...heet-vinyl.asp
framing for vinyl wind barrier (See photos) Carolyn252 Building & Construction 2 09-02-2011 05:50 PM
vinyl sheet or tile (or allure) over old vinyl? thomase Flooring 8 06-30-2008 06:15 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
