What To Do About Gaps Round Edge Of New Carpet - Flooring - DIY Chatroom Home Improvement Forum
Old 02-27-2014, 12:04 AM   #1
What to do about gaps round edge of new carpet
Hi, we have just had carpet installed in three bedrooms and a living room. Before the installation the salesman told us that we should take up the quarter round (quads). In hindsight I wish we had just asked for the carpet to be installed with these in place, because in some places we were left with quite big gaps between the edge of the floorboards and the bottom of the skirting boards. The carpet has been tucked into the gaps and looks good. But I'm concerned that over time the carpet will get dirty where the air flows through. It will be draughty too. In some places I can push my fingers into the corner and see straight down to the laundry underneath the house.
My options that I am aware of are:
- stick new quarter rounds to the bottom of the skirting boards
- try to block up the gaps. Perhaps stick some kind of foam strips down there, although I think they would either look messy or they would fall straight through. For two of the three walls where this is an issue I can access them from underneath and perhaps try to block the gaps from there.
- get someone in to insulate under the floor. Not sure if this is possible, it is pretty messy with pipes and wires and heating ducts.
- do nothing and see how it goes.
I would really appreciate any advice.
39Steph is offline   Reply With Quote
Old 02-27-2014, 12:13 AM   #2
Rewards Points: 12,818
Those floors should have been air sealed and insulated long ago.
No one here has any clue where on the planet you are so please consider taking the time to go back and adding your location to your profile.
Just go to quick links to edit.
http://www.energystar.gov/index.cfm?...sulation_table
Old 02-27-2014, 12:19 AM   #3
Thanks, I'll update my profile. I'm in Sydney, Australia. The climate is pretty mild so insulation often doesn't get much attention, except roof insulation
Old 02-27-2014, 07:58 AM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 12
Put 1/4 round back. It should have been left down in the first place.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Tags
carpet , quarter round
Tile to carpet transition BlueBSH Flooring 5 03-21-2013 01:26 PM
Gaps between dywall and carpet on stairs Mills314 Remodeling 15 03-02-2012 09:38 AM
Wet carpet on basement floor wvphysics Flooring 2 12-05-2010 02:26 PM
carpet to laminate transition 8roty Flooring 3 11-08-2010 07:41 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
