What Is The Correct Way To Redo Stair Treads. - Flooring - DIY Chatroom Home Improvement Forum
Old 10-11-2011, 09:33 PM   #1
What is the correct way to redo stair treads.
We are taking off the carpet on our staircase and want to have a runner up the center of the 5' wide staircase with hardwood stairs showing on either side.
It was suggested that we remove the nose of the stair, put a tread on top of the existing stair - but the treads are 1 1/16" which would make the last step before the landing have a shorter rise.
The other suggestion was to use the hardwood floor strips (3/4") on the stairs and put a new nosing on each stair however, this still gives us a shorter rise for the last step and would this be strong enough .
What is the proper way we should do this job?
John/Suz is offline   Reply With Quote
Old 10-11-2011, 10:20 PM   #2
They make stair caps that can be installed on top the treads that give the look of wood stairs with a runner. I buy them through our local supplier (probuild, Wisconsin building supply/stock lumber, etc)
Example:
http://www.ljsmith.net/default.aspx?category=1&page=16#.
Justgaff is offline   Reply With Quote
Old 10-11-2011, 10:39 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 116
Example:
I agree with Justgaff, they sell the tread caps in just about any wood you could want. The link to LJ Smith only showed complete stairs for me not the caps. Here is another link to some caps.
http://images.search.yahoo.com/image...mb=CtvTYYhGkmq
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 10-11-2011, 10:46 PM   #4
Coffman stairs as well... Sorry-didn't spend much time looking for link cuz I'm on my phone. Never bought these from big box stores but I do recall seeing them at homedepot-just low selection.
Google stair parts or stair caps. I found this one too: http://www.stairsupplies.com/eng/pro...71_False_Tread
Old 10-13-2011, 12:27 AM   #5
Thanks for the information. Unfortunately all these happen to be about 6" wide. Since we have a 5' stairs we would need ones about 8" wide. I will search the internet for them now that I know what they are called.
Thanks everyone for the help - if you have any other suggetions for us we appreciate it.
Old 10-13-2011, 09:11 AM   #6
We have made our own custom sizes before on several projects. You can buy the nosing material in longer sticks and just cut plywood for caps and risers. Obviously more time consuming, but if u want custom....
How to Attach Stair Treads tuchodi Building & Construction 6 07-10-2011 01:48 PM
Stair Nose Attachment - HELP! BSponz1 Building & Construction 2 01-11-2011 08:51 AM
Stair Nose Attachment - HELP! BSponz1 Flooring 3 01-10-2011 02:31 PM
installing oak stair treads advice bfan781 Carpentry 20 01-02-2011 11:56 AM
How do I install trim around stair treads? JayBird Carpentry 22 08-07-2010 05:16 PM
