What Color Thinset Should I Use? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-22-2011, 04:57 PM   #1
what color thinset should i use?
i am in stalling a black and white (daltile, Navelli, glazed porcelian) checker board patern over ditra, just wondering what color i should use, gray or white, also i plan on using kerabond for this is this the correct type to use. i understand, when mixed with water it meets the ANSI A118.1 is this correct? thanks for all your help.
prancer is offline   Reply With Quote
Old 02-22-2011, 07:25 PM   #2
Rewards Points: 1,596
I did same tile (small world) and thinset was gray. It should not bleed through with porcelain tiles. I don't remember brand; I did get it at HD; I bought the most expensive dry mix thinset (flexible bond was highlighted) since it was only a small powder room and cost wasn't an issue and I wanted them to stay down. A tile pro will amend my note at some point.
bob22 is offline   Reply With Quote
Old 02-22-2011, 09:04 PM   #3
either color will work with a porcelain tile. I am a flooring contractor by trade.
acglobal is offline   Reply With Quote
