What Cement To Help Flatten A Floor To Install Laminate Flooring? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-10-2011, 01:25 PM   #1
What cement to help flatten a floor to install Laminate flooring?
There is a section in my room that has (at it's highest point) 1.25" lower then the rest of the room. From that little step it slowly raises over about 4'.
I want to install laminate right over the concrete but this section is screwing me up.
So, in order to flatten out that area, what kind of concrete/cement do I use to fill in that area?
Thanks!
Integraoligist is offline   Reply With Quote
Old 02-11-2011, 07:16 AM   #2
if the area has voids or dips, use a self-leveling compund. this will bring area flush with rest of floor. prime concrete with latex primer using paint roller. Pour SLC onto floor. use flat trowel or float to feather edges. take your time.
acglobal is offline   Reply With Quote
Laminate Flooring Installation acourtneyvm Flooring 0 03-11-2010 02:58 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 01:20 PM
Laminate flooring to concrete abndaddy1994 Flooring 2 02-06-2010 08:26 PM
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 09:00 AM
Peninsula install on Laminate flooring? mcaanda Building & Construction 1 05-22-2008 12:01 AM
