What Is The Best Flooring To Get If You Have Dogs? - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-09-2012, 11:02 AM   #16
Rewards Points: 258
As a homeowner with both hardwood and laminate flooring, I will add my 2 cents. Let me preface this by emphasizing that it is only one person's opinion based upon use of both materials. Laminate has a harder finish than hardwood which usually has polyurehane. The prefinished hardwood (the only way I would buy it) may have a different finish. Neither finish can hold up indefinitely to the nails of a dog, however hardwood can be refinished and laminate can not. In terms of adding value to a home, hardwood is the better bet. If you were going to do the install yourself laminate would be much easier to install. One of the biggest factors in the deterioration of each is the presence of abrasive particles such as sand inadvertently brought in and ground into the floor by one's shoes. Water is another cause of damage as well. Should the dog urinate on either (not a concern based upon your question) there could be stains or other damage.
Finally, in terms of durability, I believe ceramic tiles would offer a harder surface than either laminate or hardwood even though you have not indicated any interest in ceramic.
retired guy 60 is offline   Reply With Quote
Old 10-11-2012, 06:56 AM   #17
Flooring options
Real hardwood will give you a stylish look for sure. But with dogs in place, you will have to take extra precautions about it. They can get scratched pretty easily by the nails of the dogs. So I would recommend going for laminated floors. You might feel a bit apprehensive about going for laminated floors due to them being easy to get spoiled by water. But if your lamination is full-proof and non-permeable then you will have excellent and durable flooring.
RicardoRoman is offline   Reply With Quote
Old 10-11-2012, 10:11 AM   #18
Rewards Points: 322
Animal urine is very tough on hardwoods, Maybe not now but one day when he's old he will find a secret place. By the time you find it the boards will be blackened halfway through and wil need to be replaced.
puttster
puttster is offline   Reply With Quote
Old 10-12-2012, 01:04 AM   #19
flooring solutions
Tags
allen & roth , dogs , hampton bay , laminate flooring , pergo max
Allure flooring and big dogs EFTHIM Flooring 1 05-31-2012 01:23 PM
New Flooring With 2 Large Dogs chb119 Flooring 4 04-06-2012 05:04 PM
Wife wants bamboo flooring. Two dogs pee on floor. Sowak Flooring 44 03-05-2012 05:25 AM
White dogs and wood flooring Karri Flooring 9 05-26-2009 10:54 AM
Will Laminate Flooring Hold Up With Dogs In The House? FEDERAL GOON Flooring 3 06-18-2008 01:39 PM
