What Adhesive To Use For Tiling Wall? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-20-2008, 01:45 AM   #1
sz8
What adhesive to use for tiling wall?
Hi,
I am currently tiling foors with thinset and it says it needs 24 hrs
before being stepped on.
I am planning tiling the kitchen backsplash (drywall) with 6x6 pocelain tiles.
Will the same thinset work (its instruction says so) or do I need special
kind for the wall?
Thanks,
SZ
sz8 is offline   Reply With Quote
Old 03-20-2008, 08:27 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Will the same thinset work (its instruction says so) or do I need special kind for the wall?
So......what's the problem?
Old 03-20-2008, 04:40 PM   #3
You can use mastic, but if you already have the thinset why would you buy something else?
jerryh3 is offline   Reply With Quote
Old 03-21-2008, 01:04 AM   #4
sz8
I was afraid that thinset used for foors may not work well for walls or it
is harder to work with for walls. Do we need something that can hold
tiles well on walls when tiling?
What do you guys normally use for wall tiling?
Thanks,
SZ
Old 03-21-2008, 06:55 AM   #5
Guest
Guest
Posts: n/a
Many thinsets can be hard to work with on walls but it's mainly when using large body tiles. 6x6 shouldn't be an issue with any normal thinset. Mapei UltraLite would be my recommendation for future projects. It's very lightweight and works well in just about any situation. No need to go out and but it now though if you already have perfectly good materials that will work for your needs.
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
