What Is The Actual Thickness Of "3/4" Hardwood" ? - Flooring - DIY Chatroom Home Improvement Forum
Old 07-13-2011, 12:16 AM   #1
What is the actual thickness of "3/4" hardwood" ?
Before I do all of my careful planning, I just wanted to be sure that 3/4" hardwood isn't measured the same way that a 2 x 4 is.
Is 3/4" hardwood actually 3/4 of an inch thick?
Thanks!
graysqwrl is offline   Reply With Quote
Old 07-13-2011, 07:43 AM   #2
Civil Engineer
Rewards Points: 4,854
Typically 3/4 inch thick hardwood (oak, maple, cherry) really is 3/4 inch thick. This applies only to solid hardwood. If you buy 3/4 inch hardwood veneered plywood, it could be 3/4 inch, it could be 25/32 inch, or it could be something very close to 3/4 inch, but actually metric. In the case of plywood, you need to measure it very carefully.
In the case of engineered hardwood floors, I am not certain what the nominal thickness actually means, if you get engineered flooring you need to measure the actual thickness of the specific wood you are buying, as some of it seems to be metric.
Old 07-13-2011, 03:09 PM   #3
Handyman
Rewards Points: 512
All of the engineered hardwood I have installed is actually 5/8"...I need to shim the nailer with cardboard
canadaclub is offline   Reply With Quote
Standard thickness of roof sheathing in Phoenix bethmac1221 Roofing/Siding 10 02-07-2011 07:24 PM
Plywood thickness: asked for 1/2" plywood; hardware delivered 7/16 (.437) thickness) lazzlazz Flooring 7 03-31-2010 11:25 AM
Dry wall thickness question tripower Building & Construction 14 09-02-2008 12:50 PM
Subfloor thickness?? whiskeykid Flooring 9 08-12-2008 11:06 PM
Correct thickness for brick privacy wall doingygirl Landscaping & Lawn Care 5 05-21-2008 03:49 PM
