-   -   What is this? (http://www.diychatroom.com/f5/what-17540/)
JackOfAllTrades 02-24-2008 12:39 AM
What is this?
2 Attachment(s)
I am trying to figure out what my sub floor is composed of. I can see the 1/2" or maybe 3/4" plywood that is attached to the joists. But on top of that, they used some type of board to adhere the vinyl flooring to. They glued it to the plywood & then glued down the vinyl flooring. It doesn't look like typical plywood or OSB.
1 - Did they use pressed-wood/particle board to adhere the vinyl to? :huh:
2 - I am installing porcelain tile using DITRA. Do I have to PULL the wood they used to adhere the vinyl floor to? (Mind you, they glued it down) :(
3- What would be the best way to go about this:
1/4" plywood on top of what's currently there
then DITRA
then TILE
mike costello 02-24-2008 06:43 AM
Structure Board. Rip it out, As you can see the vinyl isnt stuck to it all that well.
It was an experimental underlayment made by Wayerhouser in the early nineties.
Sucks that they glued it down , do you have enough room to go over it with something?
JackOfAllTrades 02-24-2008 11:18 AM
It will be a pain to rip it out BUT I guess that is what has to be done. If I try and put any plywood ON TOP of it, then the floor height would be too high.
It will be messy ripping it out. Will the plywood that is attached to the joists UNDERNEATH this Structure Board
be damaged when I remove the Structure Board?
After removal, should I use 1/2" or 3/4 Plywood and then DITRA?
mike costello 02-24-2008 12:16 PM
The other issues are better answered by one of our resident tile experts but yeah, you probably will scar up the plywood underneath during the tear out
JackOfAllTrades 02-26-2008 05:43 PM
I was told that I can screw 1/4" plywood to the TOP of this wafer/particle board and this will provide a good base. I then can lay thinset, then DITRA & then the tile on top.
Does this sound right? This would alleviate the disaster of trying to rip-up that wood that is glued down.
JazMan 02-26-2008 06:54 PM
Are you positive it's glued down? It really should be removed, plus you say you don't want to raise things too high, which should be a secondary concern.
You do NOT want to install any 1/4" plywood, does no good and most 1/4" isn't suitable to spread thinset over. (Who told you that, not a tile expert?) The thinnest I recommend it 3/8" underlayment, but thicker is better.
You first need to find out the thickness of the subfloor, hopefully it's 3/4" plywood in good condition. I know removing glued plywood is a pain, I did it once, never again. :censored:
Jaz
JackOfAllTrades 02-26-2008 07:30 PM
Jaz
Yes, the used LIQUID NAILS to glue it down. :furious:
Below the glued down particle board is 3/4" OSB.
If I rip out the glued particle board, will I damage the 3/4" OSB that is currently there?
Would this work?
Rip out glued particle board.:( Then attach 1/2" or 3/8" plywood USING SCREWS to the current 3/4" OSB that is attached to the joists. Giving me an 1 1/4" total subfloor. Then on top of the 1/2" or 3/8" plywood, thinset down DITRA and then put down my Porcelain tile?
JazMan 02-26-2008 10:20 PM
By gosh........that's a good plan! :thumbup: Be sure to first re-screw the OSB to the joists. Fasten the 1/2" underlayment C/C or better, (NOT the cheap CDX sheathing), only to the subfloor using 1 1/4-1 1/2" screws. Do not screw to joists with longer screws.
Jaz
JackOfAllTrades 02-27-2008 12:14 AM
Jaz
I don't understand the terminology with the "C/C or CDX"? I thought plywood is plywood.
Thanks...
mark942 02-27-2008 04:31 AM
http://www.answers.com/topic/plywood?cat=technology
JazMan 02-27-2008 03:45 PM
Well.....if you're a Jack, then you must know something about different grades of plywood, I would think. Plywood is just everything else made, it comes in many grades for various uses.
Jaz
JackOfAllTrades 02-29-2008 12:47 AM
Lowe's has 'Enhanced AC Plywood' (4x8 @ 1/2") for $27.00
They had OSB for half that price @ $13.00
Hmmm.....:huh:
JazMan 02-29-2008 11:53 AM
Yes....and your point is....? Life is always a compromise between $$ and quality. Heck I'll bet your customer could have hired another handyman instead of you for less?
I'm not sure what "enhanced AC plywood" is compared to UN-enhanced. A/C is a good grade, is it rated "exterior" or exposure 1?
Jaz
JackOfAllTrades 03-02-2008 12:23 AM
Jaz
I am doing this tile job for my home.
They didn't have the exterior rating for it. I asked the guy and he didn't know :huh:
I wanted to break-up the tile with a center "mosaic". I found 2x2 inch slate tile that is bound in 12x12 inch mesh pieces. The only problem is the slate is THICKER than the porcelain.
How would one go about, if they can, installing a slightly thicker tile for the mosaic?
The porcelain tile is 1/4" thick, the slate mosaic was 3/8" thick.
Bill_Vincent 03-02-2008 09:10 AM
The "enhanced A/C is exterior rated. As for the thickness difference, how big is the porcelain tile, and it's my understanding that you want to do the slate in the center? Or is it the other way around?
