Old 03-31-2007, 11:14 AM   #1
wetroom floor
i have a wooden tongue and groove floor and have built a walk in shower. what i need to know is how i create the slope for the drain? do i just use differing amounts of tile adhesive on the floor or is there a magic trick i am missing? i have all the waterproofing material and the dimension is 160cm by 110cm
wilma48 is offline   Reply With Quote
Old 03-31-2007, 03:01 PM   #2
wetroom floor
Whoa! Your going to have give a lot more info on this project. You've built a walk in shower and you have T&G flooring as the sub flooring? Is this the finish level the rest of the bath will be, or you plan to raise the bath floor with a slope toward the drain?
There's alot more involved in a proper walk in shower than building up with a mortar bed. I strongly sugest you visit http://www.johnbridge.com/vbulletin/index.php?
where you can get expert advice and review of your plan.
Zero Punch is offline   Reply With Quote
Old 03-31-2007, 03:19 PM   #3
wetroom floor
yeah, at the moment the T&G wooden sheets are my floor level. obviously i have built a step into the shower to allow me some depth but i am not sure if its as easy as adjusting the tile adhesive depth to create the slope?
its not a total wetroom. the area for the shower is partitioned off into a large cubicle, 160 cm long by 110cm wide.
Old 03-31-2007, 04:47 PM   #4
HJ1
tile man
wetroom floor
It sounds as though you are under the impression that you will just set tile and grout and be done. Thats not the case. Read this link for details on how to construct a shower pan.
http://www.ontariotile.com/preslope.html
Then come back here with specific questions.
HJ1 is offline   Reply With Quote
Old 03-31-2007, 10:52 PM   #5
Remodeler
MinConst's Avatar
wetroom floor
There are premade shower pans or you can build your own if you good with lead, or copper fabrication. You cannot just spread tile adhesive of any type and lay tile. You need a pan under this. I didn't follow the link HJ1 posted but I'm sure it will explain.
Minichillo's Construction
I will never leave you hanging!
MinConst is offline   Reply With Quote
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 08:57 PM
sagging floor - attach LVL? tmenting Building & Construction 3 01-30-2007 02:07 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
Floor joist lower than others drhowarddrfine Flooring 2 04-26-2006 04:25 PM
Help wih floor extremer1519 Flooring 1 12-27-2005 07:33 PM
