Old 04-03-2006, 09:34 AM   #1
Wet Flooring Replacement Question
I have a 15 x 15 section of flooring butting against the corner of my tub that I'm going to replace. Looks like the wood underneath is 3/4 OSB. The wood isn't wet any longer, but it is warped, and I want to get the tile on flat and sturdy this time. The floor is ceramic tile. There is also what looks like another 3/4" OSB underneath the first layer.
Is it possible to do the tear out and re-install 1/2" OSB and then 1/4" cement backerboard on just this section? I'm not interested in tearing out the whole floor, as it doesn't need it. But I would like this section to be permanently reinforced and prevent any further complications in this area. A good mortar job and grout will help with this, obviously, but it can't hurt to reinforce with the backerboard, I figure.
Thanks for the help!
RetroActv is offline   Reply With Quote
Old 04-03-2006, 05:57 PM   #2
Floorwizard's Avatar
Sounds like a plan. Although I would want to make sure you will install concrete board throughout the entire area right?
Floorwizard is offline   Reply With Quote
Laminate Flooring Question MillerClemsonHD Flooring 4 02-17-2007 04:49 PM
Laminate Flooring Transition Question flysndoc Flooring 1 01-29-2007 11:48 PM
Laminate Flooring Question cacell Flooring 6 03-03-2006 06:44 PM
Question about mills on laminate flooring cpsilo1 Flooring 3 07-25-2005 01:05 PM
Electrical receptacle replacement question sherlock Electrical 7 05-20-2005 04:33 PM
