Wet Floor Joists
I recently discovered a leak under my dishwasher. I think I caught it pretty soon because i only had to about 50 sq ft of subfloor damaged. I decided to pull the subfloor and ServPro was finished drying it (4 DAYS). Now that I have the subfloor up I have noticed that my floor joists are wet. Is there anything I can do or do I just need to call ServPro back out to dry the joists. Thankfully I live in SC and we are having a VERY mild winter.....(knock on wood)
http://a4.sphotos.ak.fbcdn.net/hphot...40926487_n.jpg |
Those joists look pretty moldy. I would treat them with bleach, then let them air dry for a few days. No need to get Servpro back out, unless you are in a big hurry to dry the joists. Doesn't look like there was any structural damage, just get rid of the mold, let them dry, then repair.
The joists themselves look to be structurally sound. They just have lots of mold on them. I would not try to remove the mold yourself though as you could mess up the integrity of the wood. You should call a mold abatement team to come out and remove it. They can remove it by spraying it off with dry ice.
Do NOT need hangers. Joists are resting on the sill.
I noticed as well, that you have a sheet of osb. I hope you are not using that for your sub-flooring. Osb is not made for sub-flooring!
In most areas OSB is an acceptable subfloor. I live in the midwest and it has been used for years with no problems. Just use bleach as Daniel said. It will kill the mold.
Your being given the wrong info.
There's no way anyone here from a picture can tell you those joist are fine. Someone there on site is going to have to poke around and see how deep the rot is. No mold control company I've ever heard of would suggest using bleach to treat black mold on wood like that. There going to treat it with one form or another of Boric Acid. It kills the mold and stops it from coming back. One poster gave you info on the wrong joist hanger to use. It would be one that looks like this. (Just make sure there the right hight for the joist you have.) http://strongtie.com/products/connectors/LUS-HUS.asp Then they misinformed you that OSB should not be used as a subfloor, wrong again. Only have a picture to go by but that subfloor you have looks like Advantec. OSB and Advantec as long as there 3/4" thick will work fine and has been used in millions of homes all over the world so I'm not sure where they came up with that idea. |
Hangers are not needed as the floor joists are sitting on a sill plate---No idea where that idea came from.
OSB is the most common subfloor in use today---Don't know what citation that came from either-- TCNA (tile council) book sites the use of OSB under tile---another idea without any real world experience-- Sorry about the bad info---You will find good info here along with some very weak info from a new member. |
Look again at the top of the floor joist, looks all punky to me.
Fungus eats the cellulose holding the wood fibers together causing the wood to become soft. Fungus eaten wood does not do any of the things your suggesting to look for. It just falls apart. I've seen it so bad I could snap off whole sections with my bare hands. What would make you think there was tile on that floor? Even of there was tile going to be laid you simply go over the floor with 1/2 subfloor rated plywood. Done all the time. |
| All times are GMT -4. The time now is 09:09 PM. |
