Wet Dew On Marble Kitchen Every Morning - Flooring - DIY Chatroom Home Improvement Forum
Old 06-28-2009, 11:56 AM   #1
wet dew on marble kitchen every morning
-I live in south Florida on the east coast --7th floor
-I do not use the A/C ever
-I keep the front door(to cat walk) open and the back door (to the deck) open all day--nice breeze comes through
The problem is ever morning (9 out of 10) there is a wet spot about four
feet by 2 feet in front of the door. 8am
I dry it up and it will bead up again about 2 feet. 9am
I dry it up and it will bead up again about 6 inches. 10am
By 11am it is dry
need suggestions
Jerry0609 is offline   Reply With Quote
Old 06-28-2009, 12:15 PM   #2
the Musigician
DangerMouse's Avatar
hi and welcome.
how close are you to the ocean?
what type of flooring is this? tile?
we love a good mystery here....
DM
Old 06-28-2009, 12:27 PM   #3
not marble but
Ok let see it is a marble floor not real marble but 1/4 inch marble on top
and than some backing--the floor was put in two years ago
but
the old tile floor had the same problem in the same spot
Just looked at my daily tracking of this problem--wet about 8 out of 10
days---and---this is not my unit only--(others have the same problem)
Help Help
Jerry
Old 06-28-2009, 12:35 PM   #4
the Musigician
so... water is seeping up from below between the cracks in the tiling?
DM
Old 06-28-2009, 12:57 PM   #5
If the floor has ductwork below it with AC feeding other condo's and your getting warm air/sunlight on that area you'll get condensation on the marble.
First thing I's do is try closing the doors for a day or two and see if that makes a difference.
If not then I'd call the condo association.
Shamus
Shamus is offline   Reply With Quote
Tags
wet floor
Choosing colors for painting living room, kitchen Bugpals Painting 2 05-15-2009 10:19 AM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 09:31 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 11:23 PM
