Wet Carpet From A Frozen Pipe - Flooring - DIY Chatroom Home Improvement Forum
Old 01-09-2014, 10:14 AM   #1
Rewards Points: 71
Wet carpet from a frozen pipe
Well, we're a victim of the polar vortex that came through. Even though we took precautions to prevent frozen pipes, we had one freeze and burst. It was a spigot on an exterior wall, and thankfully it was in our mudroom. We weren't home at the time, but it appears as though it was not flowing for very long as the amount of water on the floor wasn't as bad as it could've been.
The water did go from the mudroom to the adjoining room, which is carpeted. An area approximately measuring 3'x3' was wet. I immediately used a carpet cleaner to suck up the water, or as much as I could get up. I have since placed a dehumidifier in the room (although, I don't see any water in the catch basin, so not sure if it is doing anything). When we first arrived home, the carpet was "squishy" - when you walked on it, you heard a noise and it was clearly wet. Now, although wet, it feels like a freshly cleaned carpet (maybe a little more wet than that, but definitely not "squishy").
So I'm wondering, what else should I do? I've read about pulling the carpet back, but with such a small area that is wet, I'm wondering if I need to do that? If pulling it back is necessary, I'm not even sure how I'll go about getting the carpet put back down correctly after all is dry.
thaKing is offline   Reply With Quote
Old 01-09-2014, 11:02 AM   #2
Rewards Points: 14,312
Carpet needs to be pulled back, padding cut out so the subfloor can dry out.
Replace the padding with new.
A simple knee kicker can be used to get it tight again.
Old 01-09-2014, 11:17 AM   #3
Rewards Points: 71
There has to be a simpler way!
OK, two questions:
1) what is the best way to pull up such a small area? Guessing I need to remove the baseboard in the room (at least on two walls) and pull it up from there?
2) are knee kickers rentable? I know the basic idea behind using a knee kicker - just knee it and make sure that the kick gets the carpet stretched AND connected to the tack strip?
Old 01-09-2014, 11:40 AM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
If it was properly installed, it won't be under the baseboard. Just grab it next to the wall with a pair of pliars and pull it up. There are several videos on youtube showing how to use a kicker.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 01-09-2014, 11:42 AM   #5
Rewards Points: 71
Hmm, with my luck it won't be properly installed. Haha
Seriously though, thanks for that tip. I know what my evening will consist of now. :D
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 05:53 AM
Hot water pipe frozen d_heath Plumbing 1 02-10-2013 03:01 PM
Carpet Flooding and Replacement airjay81 Flooring 1 05-08-2012 12:00 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
Good equipment to use for carpet cleaning? Beth777 General DIY Discussions 5 08-29-2008 08:16 PM
