Old 09-25-2006, 04:28 PM   #1
Which way to run hardwood ?
I'm going to be installing a hardwood floor in my foyer that opens up to the kitchen at the end of it and a den to the right side.
The foyer is 15ft long and 7ft wide.
My questions is: should I lay the floor the length of the foyer or the width of the foyer. Seems there is less chance for error if I'm going a short distance, 7ft, compared to probably about 35ft if I go length.
Is this just a personal preference thing ?
wdsfr1968 is offline   Reply With Quote
Old 09-25-2006, 10:50 PM   #2
Usually wood/ laminate flooring is run down from the light as it looks more pleasing but it is not essential, just lay some down and see which way you like best.
lxdollarsxl is offline   Reply With Quote
Old 09-26-2006, 08:33 AM   #3
Master Craftsman
Big Dave's Avatar
If you are installing nail down flooring then it should be installed perpendicular to the direction of the joist. If it is floating then it doestn't matter.
Dave.
Do one thing at a time, do it well, then move on.
Big Dave is offline   Reply With Quote
Old 09-26-2006, 11:37 AM   #4
I've always heard it's easier to run the floor along the long edge, as it means less cutting and likely less waste.
billinak is offline   Reply With Quote
Old 09-26-2006, 04:17 PM   #5
It seems that running it the long way would mean it would be harder to nail the pieces that are close to the wall. It would be difficult to get the nailer in place as you would be up against the wall on either side.
Old 09-26-2006, 07:27 PM   #6
Master Craftsman
Big Dave's Avatar
That is true. The way I do it is to get as close as you can with your flooring nailer then take your trim gun and nail through the tounge for a few more rows then the last 2 or 3 rows have to be top nailed.
Dave.
Old 09-26-2006, 08:47 PM   #7
wood floors look better runnung the long way of the room. just snap a line so you have a stait reference to work from. what is your subfloor? it is true that you should run perpendicular to joist, but if you have a pine board tounge and groove floor, you should run opposite of that.
jamesdart is offline   Reply With Quote
Old 10-03-2006, 09:48 PM   #8
The Flying Toolbox
handypilot's Avatar
Dave.
With a sound subfloor, why does it make a difference?
Not debating...just wondering why.
handypilot is offline   Reply With Quote
Old 10-03-2006, 09:58 PM   #9
Master Craftsman
Big Dave's Avatar
No matter how sound your subfloor is it will still flex. If you run your hardwood with the joist then it is going to flex easier than if you ran perpendicular. You also run the risk of over time the plywood sagging between the joist thus giving the floor a rolling ocean look if the hardwood is run with the joist. That being said on a small hall it would probably never be noticed. But as stated above the flooring does look better running the length of the hall.
Old 10-06-2006, 11:04 AM   #10
You can just put a 1/2 inch worth of plywood down on top of the subfloor if you want to go parrell with the joists. Thats what i was told by a number of flooring contractors to help stiffen it up and not flex.
AllGoNoShow is offline   Reply With Quote
Old 10-06-2006, 12:46 PM   #11
I blame ProWallGuy
Dave is still correct. You're never going to get all the flex out, and if the floor should flex, running with the joists puts less stress on the hardwood.
Adding 1/2" ply is not always an option. Flex is more a function of the joist sizing and span than the subfloor and substrate. Adding more substrate will help, but not eliminate the problem.
Double A is offline   Reply With Quote
Old 10-06-2006, 05:21 PM   #12
The Flying Toolbox
handypilot's Avatar
Thanks Dave!
Old 10-06-2006, 07:49 PM   #13
Run it the length of the floor, apparently this this the fung shui way, not that I believe any of that BS, but the rich new age people buying your house when you move out may believe it.
DWrath is offline   Reply With Quote
Old 10-06-2006, 10:01 PM   #14
Generally, - - running it parallel with the long wall looks much better.
Running it the other way gives it a 'ladder' effect, and makes the room look smaller.
Tom R is offline   Reply With Quote
Pattern of hardwood to existing hardwood floors garnet4ever Flooring 4 07-31-2007 04:34 PM
old termite damaged hardwood Kbotard Flooring 8 05-14-2007 03:22 PM
New Hardwood and Toe Kick yogibayer Flooring 2 03-19-2007 09:22 AM
