Old 06-29-2011, 11:51 PM   #1
Which way to lay down the laminate
Don't laugh at me please. I have a Living Room, that leads to 2 hallways and then 3 bedrooms...all in laminate.
I made a nice picture showing the way I was thinking of running the boards.
Good to go, as I am having a debate with my dad - he thinks E and F should be run North and South and make a transistion between the 2 hallways.
Also wondering if you'd go directly from hallway to bedroom continuous or would you make a transistion from hallways to bedrooms?
Thanks!
hellothere123 is offline   Reply With Quote
Old 06-30-2011, 07:08 AM   #2
woodman58's Avatar
The wood should be run accross the floor joists. The doorways do not need transitions.
woodman58 is offline   Reply With Quote
Old 07-01-2011, 10:34 AM   #3
Architectural Designer
AGWhitehouse's Avatar
It's personal preference. If you want the back rooms turned North-South then I would recommend carrying the E-W flooring in the hall all the way to the wall and then have the change happen on either side. This way when you are looking down the hall from what I assume is the living area you don't see the flooring transition.
AGWhitehouse is offline   Reply With Quote
Old 07-02-2011, 02:00 PM   #4
Ditto on the personal preference... thoughts to consider are
--- running it crossways to incoming daylight will hide structural imperfections
--- down a hallway will make hall look long and narrow versus crossways will look shorter and wider
--- doorway transitions will make installation easier , direction change possible, but leaves um.... a bump
DON'T FORGET KNEEPADS!
HarryJ is offline   Reply With Quote
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
countertops-to tile or relaminate? mudpaw Remodeling 11 10-02-2011 10:43 AM
New Laminate Floor Installation Creaks.... c3uo Flooring 13 07-12-2011 01:43 PM
laminate moving in one direction nlmedic Flooring 2 03-01-2011 08:38 PM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 01:04 AM
