-   -   wavy subfloor problem (http://www.diychatroom.com/f5/wavy-subfloor-problem-3641/)
baltimore 08-24-2006 07:51 PM
I recently moved into a 3 year old gemcraft house and I would like to tile the kitchen. the problem is that the osb subflooring used for the floors is very wavy under the linoleum. i am told that this is a result of not allowing proper drying time. if i want to make the tile look correct, is taking up the old subfloor my only option, and if so, will i definetly have to remove the cabinets? Any advice would be appreciated. thank you.
Donedat 08-24-2006 10:38 PM
Slow down now. Just secure the old sub-floor with quality screws and set your underlayment and then level the floor with the appropriate mortar product, then as you set your tile with thin-set, you can fine tune it to a perfect flat and level surface you are envisioning.
Tile guys will have more to say on this. I've just watched it done out of the corner of my eye while I was laying hardwood.
