Wavy Hardwood Floor - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-11-2010, 12:08 PM   #16
Quote "In the first pic you can see one of the larger gaps between the ends of the boards. There are maybe 12 places like this. But we found no evidence of wavyness, at least not in the dining room. "
I think the wavyness he had originally seen when the carpet was down has been eliminated by what he said in subsequent post.
roxksears is offline   Reply With Quote
Old 01-11-2010, 06:56 PM   #17
RetiredSoldier's Avatar
Rewards Points: 27
I'm sorry. I guess I didn't make it clear that the wavyness was not a problem on this part of the floor. In the dining area I seem to be having the gap problem at the ends of the board.
Once again, I apologize for the confusion.
RetiredSoldier is offline   Reply With Quote
Old 01-11-2010, 07:00 PM   #18
Rewards Points: 27
Originally Posted by pinwheel45 View Post
Your floor was put together with pretty common practices of the day. After looking at the pics you posted from below, I'd say the majority of your are coming from flexing in your floor. Looks like your floor joists are 2x8 at best. Do you feel the floor bouncing when you jump up & down on it? Floor squeeks usually come from wood to wood contact & one or both pieces of wood that are in contact moving against each other.
A pretty simple way to test my theory would be to tack a 4x4 to the bottom side of the floor joists & put a couple 2x4 legs down to the basement floor & then walk across your floor & see if it doesn't take away at least some of the squeeking. If it does, then you can sister 2x's on the sides of your floor joists to stiffen them up. Another trick, is to run a bead of construction adhesive right where the floor joists meet the subfloor.
What do you mean by wavy? I don't see any cupping in the boards in the pictures.
The joists look to be 2x10. I'd have to measure to be sure. But I don't feel any bouncing in the floor. The joists are no more than 12ft long, because they only span half the width of the house. The ends rest on a beam and the foundation.
Old 01-12-2010, 08:27 AM   #19
The squeeks are wood to wood contact that's moving. Need to narrow down where you're getting that movement before you can solve the problem. As for the gapping on the ends, that's not something I'd get real excited about. Color putty filler will have a matching premixed color. . I buy it at Ace. Wood does not expand lengthwise, so it's not going to get worse.
pinwheel45 is offline   Reply With Quote
Old 01-13-2010, 07:16 PM   #20
msv
Hardwood pro
msv's Avatar
you're probably gonna refinish those floors, right? if so, you can fill the gaps with wood filler(putty) between sandings. about the squeaks... get one person in the basement and one walking on the problem spots... the one in the basement can tell if the subfloor is moving relative to the joists... if so, drive screws from the bottom through the joists into the subfloor boards(careful not to go through the flooring, though). if it;s not the subfloor moving, it means it's the flooring. you can face nail those boards moving against each other, set the nails and use matching wood putty....
good luck...
50% down, 50% after all your complaints....
Hardwood Floor Refinishing Roswell
msv is offline   Reply With Quote
Old 01-13-2010, 07:37 PM   #21
Rewards Points: 27
Thank you all for the great advice. I'll put it all into my corrective measures.
Old 01-13-2010, 09:21 PM   #22
Civil Engineer
Rewards Points: 4,854
There does not appear to be anything wrong with your subfloor, I have exactly the same type in my house, with 3/4 inch hardwood above it, no problems. I cannot tell from the photo exactly what you have for flooring, it looks like oak, but it may be a preengineered type of flooring. The gaps between the ends of the boards are almost certainly not caused by the subfloor, as there is no reasonable way the subfloor could expand or contract sufficiently to open that size gap where it shows. I think it is possible that the floor was put in that way, as odd as that sounds.
The reason I am wondering if this is preengineered wood rather than 3/4 inch boards is that normally boards are tongue and groove, even on the ends, and unless someone cut the tongues off, that gap looks like it goes all the way to the subfloor level.
Old 01-13-2010, 09:40 PM   #23
Rewards Points: 27
Actually it is oak hardwood. If you look straight down at the gaps, you can see the tongue.
Old 01-18-2010, 05:47 PM   #24
Rewards Points: 27
You are right, the joists are 2x8. However, they don't flex when someone walks across or jump on them. I do see the subfloor boards flex when walked over.
So with that in mind I think I'd like to screw strips of 3/4" plywood to the underside of the subfloor. I'd make them fit snuggly between the joists. Then I'd use longer screws to pull the oak floor tight to the subfloor & 3/4 plywood. Does this sound like a good fix? Or is there a better way?
Old 01-18-2010, 06:13 PM   #25
Are the floor joists on 24" centers? I wouldn't think you'd get much flex on 16" centers.
Yeah, you could do exactly what your proposing. May, or may not fix the problem. Should stiffen up the subfloor though. I'd cut at least 1/4" undersized on each side though. #1, no sense fighting with the plywood to get it in there, #2, avoid edge contact with the plywood so you don't potentially create another point to cause squeeks.
Old 01-18-2010, 10:41 PM   #26
Rewards Points: 27
Your right 16" on center. I think the flexing may be due to poor board quality. I checked again and found alot of knots and knot holes. Also alot of boards with only what I can describe as a feathered look. The wood fibers are separated. But there is no evidence of water damage or pest damage. Good point about the snug fit = squeeks.
Old 01-24-2010, 12:46 AM   #27
It's just an old house that has settled a bit unevenly. Mine was built in the 1930s, and we have the same "problems." Idon't think there is much you can do about all the low points and squeaking, unless you have a lot of time and/or a bit of money to invest. This is par for the course I think for older homes, and is usually not a danger - did you have the home inspected?. I just tell my wife that - when our 4-year-old daughter is old enough to try it - there will certainly be no successful sneaking out at night. Haha.
My Old House is offline   Reply With Quote
Hardwood floor stripping problems cmdrico7812 Flooring 3 09-13-2011 10:58 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
Hazy dusty look on hardwood floor lleegle Flooring 4 07-26-2008 10:04 AM
can engineered hardwood be a floating floor? smythe01 Flooring 10 07-09-2008 10:16 PM
Clear Hardwood Floor Finish With Buildup CuCullin Flooring 3 11-18-2007 02:26 PM
