Waterproofing New Construction Shower - Flooring - DIY Chatroom Home Improvement Forum
Old 01-04-2011, 09:54 AM   #1
waterproofing new construction shower
This is a 2 part opinion/questions. Has anyone heard or used a membrane material called Mer-krete?
I am building a new home and the builder swears by this stuff. He is planning to use it to waterproof the tile shower and also in place of a backer board in the kitchen? I know cement board is not supposed to add structural support so is this ok to use?
thanks!!
dyers78 is offline   Reply With Quote
Old 01-04-2011, 10:08 AM   #2
Chicago, IL
Michael Thomas's Avatar
They might be referring to their Hydro Guard waterproof crack isolation membrane, which can be used over backer boards and under tile. This would work on shower walls but could not be used to form a pan liner, and would not be as "seamless" a form of shower construction as a continuous pan and wall "liner" created with the with Kerdi or similar products.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 01-04-2011, 11:59 AM   #3
Tileguy
JazMan's Avatar
Rewards Points: 388
Mer-Krete has excellent systems for any tile installation. It'll work fine as long as all details are followed, as with anything else. If you trust him, go for it. You should learn more and double check as work progresses.
I like Kerdi and Ditra, but Schluter has done a better job in promoting their stuff. I consider Mer-Krete more of a product aimed at commercial projects.
Jaz
Old 01-04-2011, 12:09 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If it is a trowelable/paint-able membrane it is only as good as the guy that makes the application. Those type of membranes can be tricky in some applications and they aren't products that you would want to take any shortcuts with.
XXX
Proper construction of shower knee wall lawyer101 Remodeling 2 12-19-2013 08:47 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Questions on waterproofing tile walls for shower with floor pan. HautingLu Tiling, ceramics, marble 11 09-18-2009 11:12 AM
Waterproofing a shower window seacuke23 Tiling, ceramics, marble 3 08-24-2009 01:20 PM
waterproofing shower nook ponch37300 Kitchen & Bath Remodeling 3 04-10-2009 08:18 AM
