Old 02-21-2012, 09:27 AM   #1
Waterproofing Laminate Flooring
Renovating my condo and would like to extend the laminate flooring from the hallway into the laundry closet but worried about moisture ruining the flooring. Is there a surface coating that can be applied to the laminate that will protect it from water spills, etc? If not I'm going to lay tiles down.
albany is offline   Reply With Quote
Old 02-21-2012, 10:07 AM   #2
JetSwet's Avatar
Look into the Allure by traffic-master vinyl planks that look like lamenant but waterproof.
Sent from my iPhone 4 ios5
JetSwet is offline   Reply With Quote
Old 02-21-2012, 11:33 AM   #3
No waterproofing material will work since it can't saturate 100% of the product. The trafficmaster allure is definitely a good option to look at. @$3 a square foot it's in a decent price range and looks good to start. How it will hold up though, who knows so far.
MarkusAIC is offline   Reply With Quote
Old 02-22-2012, 05:24 PM   #4
What type of laminate flooring are you looking to lay down? Most are manufactured with built-in moisture resistant technologies such as cores that resist water or aluminum-oxide style finishes.
aaron_david is offline   Reply With Quote
Old 02-24-2012, 07:49 AM   #5
A Little Of Everything
Laminate flooring - regardless of the quality and expense - will have moisture problems in two ways. First, the seams. You can "kind of" seal them, but with the way the floor flexes, any seam sealing will crack and allow a certain amount of moisture in. Second, is scratches that go through the surface.
Personally, I'd lay ceramic tile in a laundry room. It's only a matter of time before the vibration of the washer & dryer wears through the surface of laminate, and moisture gets in.
DrHicks is offline   Reply With Quote
Old 02-24-2012, 08:25 AM   #6
JetSwet's Avatar
Laminate is used alot in laundry rooms and kitchen I wouldn't worry about moisture issues with laundry rooms but that's just my thoughts.
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 07:37 PM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 03:55 PM
How do you install laminate flooring under door casings? Player Flooring 34 07-16-2010 05:55 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 02:20 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
