-   -   Waterproofing Laminate Flooring (http://www.diychatroom.com/f5/waterproofing-laminate-flooring-134471/)
albany 02-21-2012 09:27 AM
Renovating my condo and would like to extend the laminate flooring from the hallway into the laundry closet but worried about moisture ruining the flooring. Is there a surface coating that can be applied to the laminate that will protect it from water spills, etc? If not I'm going to lay tiles down.
JetSwet 02-21-2012 10:07 AM
Look into the Allure by traffic-master vinyl planks that look like lamenant but waterproof.
Sent from my iPhone 4 ios5
MarkusAIC 02-21-2012 11:33 AM
No waterproofing material will work since it can't saturate 100% of the product. The trafficmaster allure is definitely a good option to look at. @$3 a square foot it's in a decent price range and looks good to start. How it will hold up though, who knows so far.
aaron_david 02-22-2012 05:24 PM
What type of laminate flooring are you looking to lay down? Most are manufactured with built-in moisture resistant technologies such as cores that resist water or aluminum-oxide style finishes.
DrHicks 02-24-2012 07:49 AM
Laminate flooring - regardless of the quality and expense - will have moisture problems in two ways. First, the seams. You can "kind of" seal them, but with the way the floor flexes, any seam sealing will crack and allow a certain amount of moisture in. Second, is scratches that go through the surface.
Personally, I'd lay ceramic tile in a laundry room. It's only a matter of time before the vibration of the washer & dryer wears through the surface of laminate, and moisture gets in.
JetSwet 02-24-2012 08:25 AM
Laminate is used alot in laundry rooms and kitchen I wouldn't worry about moisture issues with laundry rooms but that's just my thoughts.
