Water Substitute Additive To Grout For Permanent Sealer - Flooring - DIY Chatroom Home Improvement Forum
Old 01-12-2012, 04:15 PM   #1
Rewards Points: 562
water substitute additive to grout for permanent sealer
Mennards has a product that is used instead of water when you mix grout up. they say you never have to seal that, ever. Is this a viable option on non owner occupied dwellings where cant seal every little while, let alone remember to. Dont think is was all that expensive, just got a fast look and a point cause they were so busy,,,,I was just shopping anyway. Or is the epoxy grout the way to go??
4just1don is offline   Reply With Quote
Old 01-12-2012, 08:44 PM   #2
Rewards Points: 944
I've tried some of this stuff, but it hasn't been down long enough to know.
The cost is considerable. I think you'll pay $12 for a sack of grout and maybe up to $35 for the additive for one sack. But it is still much less expensive than epoxy or urethane.
I think the color will matter. If you think it will keep white grout white, you had better think again.
They offer it in a bigger bottle at h/d for less money, but I don't know if it is a comparable product.
It does seem to make the grout set up faster, or maybe I'm just imagining that.
cleveman is offline   Reply With Quote
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
TrafficMaster grout f.y.i. denman Flooring 16 07-01-2007 03:07 PM
