-   -   water substitute additive to grout for permanent sealer (http://www.diychatroom.com/f5/water-substitute-additive-grout-permanent-sealer-129723/)
4just1don 01-12-2012 05:15 PM
Mennards has a product that is used instead of water when you mix grout up. they say you never have to seal that, ever. Is this a viable option on non owner occupied dwellings where cant seal every little while, let alone remember to. Dont think is was all that expensive, just got a fast look and a point cause they were so busy,,,,I was just shopping anyway. Or is the epoxy grout the way to go??
cleveman 01-12-2012 09:44 PM
I've tried some of this stuff, but it hasn't been down long enough to know.
The cost is considerable. I think you'll pay $12 for a sack of grout and maybe up to $35 for the additive for one sack. But it is still much less expensive than epoxy or urethane.
I think the color will matter. If you think it will keep white grout white, you had better think again.
They offer it in a bigger bottle at h/d for less money, but I don't know if it is a comparable product.
It does seem to make the grout set up faster, or maybe I'm just imagining that.
