Old 11-14-2011, 08:18 AM   #16
Water 'seeping' from linoleum on top of tile
There was no rocking or anything before I removed the toilet... the flange seems to be solid as far as being anchored to the concrete. My only concern is there is some deterioration (or absence) of concrete around the flange (between the end of the tile and flange), and there is a bunch of mold/crud in there... but I'm not sure if this is just how it was constructed, or if there's water seepage from under there. Oh, I should mention, the house is from 1975, and I've done a bunch of other work on it... In my observations, not much if anything has been updated since. This is probably a wax ring from that year.
From what you guys are telling me, probably no issue below the actual lip or ring of the flange, as far as a possible leak goes. I think I'm also in agreement that it's just a bad seal, I just want to be sure before I put a new toilet back on there.
I will continue my fight against the mold and grime--and then post a new pick so you guys can look at exactly what I'm talking about.
ewerbeck is offline   Reply With Quote
Old 11-14-2011, 08:22 AM   #17
Super Moderator
That ring was never right--that's why they caulked the toilet to the floor---
Old 11-14-2011, 08:52 AM   #18
General Contractor
Mike's right, a thicker wax ring will work fine. Much better than trying to raise that on a slab floor.
No doubt the toilet didn't rock/move with being caulked to the floor. You can see where the vinyl floor was installed without removing the toilet and then caulked in around it.
It's an ongoing debate whether toilets should be caulked to the floor, even when the finished floor is installed correctly/under the toilet. I'm on the side that doesn't caulk toilets.
dsconstructs is offline   Reply With Quote
The Following 2 Users Say Thank You to dsconstructs For This Useful Post:
ewerbeck (12-27-2011), oh'mike (11-14-2011)
Old 12-27-2011, 06:36 PM   #19
Alright guys... I want to thank you for all the advice. I've been MIA because I've been working on the project. Took me longer than I wanted it to, but I got ill half-way through it and had to special order the toilet (Rough-in was less than 12 inches). Here are some pics below. I thought you guys would like to see what you helped me do. Thanks again. I'm happy with the results.
Go to this site for the full album of pics (24): https://picasaweb.google.com/ewerbeck/December272011
Otherwise, here is a couple...
Old 12-27-2011, 06:41 PM   #20
I should add that I DID NOT caulk the toilet.
Old 12-27-2011, 06:48 PM   #21
Super Moderator
Handsome and professional looking---Your hard work paid off!!!---Mike---
Old 12-27-2011, 06:51 PM   #22
General Contractor
Huge improvement, nice job
Old 01-02-2012, 11:51 AM   #23
Thanks everybody... It was my most complicated undertaking yet... now on to the guest bath. Hopefully I won't need to bug you guys with different problems!
Tags
flange, leakage, tile on concrete slab, wax ring
Travertine Tile Help MikeinTexas Flooring 1 09-07-2011 11:43 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Lost Hot water pressure brile Plumbing 11 11-28-2010 03:59 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
