Water Damage In Bathroom - Flooring - DIY Chatroom Home Improvement Forum
Old 05-17-2009, 05:03 PM   #1
Water Damage in Bathroom
I just tore out old sheet vinyl in my bathroom to discover water damage on the underlayment. I started pulling out the underlayment to discover that the subfloor is also damaged. The damage is around the toilet and both corners of the tub. What is the best way to proceed?
Also, I was planning on laying 1/4" backerboard before laying my new ceramic tile. Will that suffice for an underlayment after replacing the rotted subfloor?
mrs_hawkins is offline   Reply With Quote
Old 05-17-2009, 07:57 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 240
You will not be able to remove all of the bad plywood unless you remove the tub too and start over. It probably isn't necessary, especially if you have excess from below the room to add blocking. Once the new subfloor is in, 1/4" backer should be enough if you're installing ceramic or porcelain tiles.
Jaz
Tags
subflooring , tile floor , underlayment , water damage
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
hot water check valve? Ultrarunner2017 Plumbing 7 01-30-2009 02:36 PM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 11:29 PM
Bathroom floor wet; water coming _out_ of bath overflow. oceanclub Plumbing 6 01-09-2008 10:47 PM
