Want To Replace My Pergo Laminate Wood Flooring In Kitchen - NEED HELP - Flooring - DIY Chatroom Home Improvement Forum
Old 11-08-2010, 09:59 AM   #1
Sephora's Avatar
Rewards Points: 150
Want to replace my Pergo laminate wood flooring in kitchen - NEED HELP
We just installed new cabinets and counters. When they removed the old cabinets I noticed that there was about 2 layers of linoleum underneath...I knew something else was under as the kitchen floor is higher than our regular wood floors in the other rooms that join the kitchen.
Anyways, we added new cabinets to one side of the kitchen and they put them on top of the Pergo and supplimented wood in the areas were they took ould the old cabinets so everything was the same level.
My question is: How can I cut around my new cabinets to remove the Pergo? I dont' want to disturb the old linoleum as I am not sure if they contain asbestos. The hosue was built in 1965.
Any tips/advice/help would be greatly appreciated.
We plan to put Pergo-like laminet tile looking down.
Sephora is offline   Reply With Quote
Old 11-08-2010, 04:30 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
UNBELIEVABLE !!!
(That any legitimate cabinet installer would do that.)
There is a tool called a toe-kick-saw made to do just what you are needing to do. Be advised if you rent one or buy one it is one of the most dangerous tools there is in the hands of a novice. BE CAREFULL.
You could also use a tool like a Sonic Crafter made by Rockwell, Fein, (and others).
XXX
Old 11-11-2010, 09:50 AM   #3
Sephora's Avatar
Rewards Points: 150
Well the floor was not part of the deal. And since I added new seciton of cabinets where the Pergo originally went I don't see a reason why they would remove the part.
So I am guess a saw would work...my hubby is not handy with those so we might have to hold off!
Wood Laminate in the Kitchen quesenbarrett Flooring 4 03-21-2011 01:58 PM
Laminate flooring in kitchen haniafil Flooring 1 06-08-2010 08:31 AM
Newbie w/a flooring question Laminate v. engineered wood UNCgal91 Flooring 2 08-25-2008 07:29 PM
Wood Flooring in Kitchen Calico Flooring 2 10-10-2007 04:46 PM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 03:29 PM
