Walls On Top Of Particle Board That Got Wet - Flooring - DIY Chatroom Home Improvement Forum
Old 08-24-2007, 02:48 PM   #1
Question
Walls on top of particle board that got wet
I have several walls that were built on top of an existing floor that consisted of particle board on top of 1x6s. The particle board got wet, and had to be removed, but remains under the walls. I plan on installing 3/4" T&G plywood to replace the particle board, but what should I do about the particle board remaining under the walls? Advice is solicited. Thanks!
Bruno2000 is offline   Reply With Quote
Old 08-24-2007, 03:07 PM   #2
Mod / ArchiBuilder
Cole's Avatar
How much of it got wet underneath the plates?
How thick is the particle board subfloor?
Cole is offline   Reply With Quote
Old 08-24-2007, 03:30 PM   #3
Most of it (if not all) got wet. The particle board is 3/4" (now removed except under the walls) on top of 1x6s. None of the walls are load bearing, but I am concerned about the particle board disintegrating, the walls slumping, and the sheetrock cracking. Thanks!
Installing backerboard - replace particle board? salvop Flooring 10 04-29-2011 11:32 PM
wall sheathing, foam board, insulation and house wrap dr.demento Building & Construction 10 10-18-2007 05:42 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
Particle board underlayment help diynut Flooring 5 03-07-2006 06:22 AM
particle board / hardibacker fish3211 Flooring 4 08-10-2005 09:32 PM
