Wall Trim Options For Tiled Entryway Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 05-11-2012, 08:23 PM   #1
wall trim options for tiled entryway floor
I'm laying a 26x17 inch tile over Hardiebacker board that is both thinset and screwed into place above the subfloor in my entry way. Thank you DIY chatroom for at least getting me this far.
The problem is that the porcelain tiles don't have a bullnose trim pieces that match, this color and style only come in 26x17 sizes.
One option that I have is ripping down a few tiles to 26x4 with the tile saw.
Can I just put the tile on the wall without a bullnose, since this is an entryway and not a shower?
I could ease the upper edge with the course side of a knife sharpening stone if there was anything sharp.
What other way can I get a decent eased tile edge without buying a $200 diamond saw wheel with a bullnose profile?
aspeek is offline   Reply With Quote
Old 05-11-2012, 08:43 PM   #2
Pro
JetSwet's Avatar
Rewards Points: 502
I would say the only 2 options for you is rent a diamond blade grinder or get a tile that has the edge you need but your right it won't match.
JetSwet is offline   Reply With Quote
Old 05-11-2012, 09:28 PM   #3
Rewards Points: 13,300
What does the tile butt up againt that your trying to trim out?
A picture sure would help.
Old 05-14-2012, 12:45 PM   #4
here are 2 shots:
http://tinypic.com/view.php?pic=2rhl4pt&s=6
http://tinypic.com/view.php?pic=30lgv92&s=6
I think I'm going to just use the same baseboard as the wood floors and not over think it that much, but any ideas appreciated
Old 05-14-2012, 05:05 PM   #5
3rd shot you can see just plain drywall above the tiles
wall trim options for tiled entryway floor-entry_tile.jpg   wall trim options for tiled entryway floor-entry_tile2.jpg   wall trim options for tiled entryway floor-entry_tile3.jpg
Can I remove this wall? limited60 Remodeling 9 06-05-2012 02:32 AM
Fireplace trim options - hardwood floor joemontana16 Flooring 2 01-15-2010 04:28 PM
Options for Cold Basement Concrete Floor? jefferis Flooring 16 12-09-2009 01:23 PM
Supporting floor joists on non-load bearing wall? ct9359 Building & Construction 4 07-17-2009 01:59 PM
Building Wall Over Floor bradarth Flooring 2 07-11-2005 11:15 PM
