Wall Separating From Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 08-16-2011, 09:05 AM   #1
Wall separating from floor
Our house in on a concrete slab, we have no basement, our wall has separated from the floor. The wall is an exterior wall, everyone has a ton of solutions and what is wrong, but I am not sure what to do next. I have asked a contractor and he said dig a hole in the yard and remove the floor. HELP
lisajondylan is offline   Reply With Quote
Old 08-16-2011, 10:30 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 112
At one time, they would pour footings for the outside walls and then pour the slab floor separate. If they didn't prepare the ground properly the floor would sink away from the walls. There are companies that can inject concrete under the slab and raise it back into place. Not a DIY project.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 08-16-2011, 11:22 AM   #3
Rewards Points: 112
In the Ruskin area of KC, they built hundreds of homes in a hurry for defense workers during WW2. They built them like I desctibed in the other post and didn't tamp or roll the ground. In some of them the floors have sunk 6-8 inches. Most are cheap rentals.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Basement floor leaking after wall repair unfortunateluck Building & Construction 6 02-15-2011 06:05 PM
Sub floor Dry rot under wall Subcooled Building & Construction 3 02-13-2011 11:11 PM
WET concrete wall under TOP floor bathroom window---how to stop? Dyoung Building & Construction 8 02-13-2010 10:14 PM
