Wall Mounting Of Hardwood Behind A Wood Stove - Flooring - DIY Chatroom Home Improvement Forum
Old 01-17-2010, 10:16 AM   #1
Wall Mounting of hardwood behind a wood stove
I am thinking about installing hardwood floors behind my wood stove on the wall. Any thoughts if this is not a good idea?
thanks
Great Ideas is offline   Reply With Quote
Old 01-17-2010, 07:26 PM   #2
firehawkmph's Avatar
Rewards Points: 1,800
Every been inside a house fire, while it was going? Depending on how close you put the wood, it could be a serious problem. Even if you follow the clearances recommended by the stove manufacturer, do you really want to trust that? Something non-combustable would be a better and much safer idea.
Mike Hawkins
Ret. firefighter after 25 yrs.
firehawkmph is offline   Reply With Quote
Old 01-17-2010, 07:28 PM   #3
i would consider a ceramic plank. wood scares me near fire.
just tile is offline   Reply With Quote
Old 01-17-2010, 07:46 PM   #4
You usually need 18" between the stove & combustibles, some need as much as 36" - usually older stoves
Not a good idea to have the wood there
The heat from the stove will not have a good effect on it
there is some evidence that wood which is constantly exposed to temperatures above 250F can eventually turn to charcoal and present an ignition danger. Keep in mind that certain “safe” temperatures can still cause certain finishes and paints to fail and/or woods and other soft materials to warp or buckle.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
"Defogging" double-pane windows .... a gimmick?? alexz General DIY Discussions 133 03-10-2010 01:35 PM
Wood Stove Blower question Alan HVAC 6 11-27-2009 10:49 PM
subpanel mounting on concrete basement foundation wall bulk88 Electrical 12 03-10-2009 02:38 PM
Mounting a flatscreen TV on a sheetrock wall TanMan Building & Construction 14 02-16-2009 05:26 PM
