Vinyl On Vinyl On Tile On Concrete - Flooring - DIY Chatroom Home Improvement Forum
Old 03-15-2013, 09:04 PM   #1
Vinyl on Vinyl on Tile on Concrete
Like the title says, my bathroom has vinyl on top of vinyl on top of tile on top of concrete.
I want to replace the vinyl with new vinyl. My thoughts are to remove the top layer of vinyl and then put 1/4" AC plywood on top, then vinyl over that.
If I were to do it that way, how do I fasten the plywood to the subfloor? Or is there a better way?
blau808 is offline   Reply With Quote
Old 03-15-2013, 09:09 PM   #2
Rewards Points: 13,694
I'd get rid of all of it, and install directly to the concrete.
Plywood can not be layed over a slab.
Old 03-15-2013, 10:55 PM   #3
Floor Installer
sam floor's Avatar
Rewards Points: 154
You can take up everything except the tile and install IVC vinyl on top of it. It can be glued or loose layed.
sam floor is offline   Reply With Quote
Mannington Adura Vinyl Tile digitaljimmy Flooring 2 02-03-2013 02:19 PM
laying stamped concrete over old tile Kimmarie Flooring 24 03-20-2012 12:20 PM
Installing Ceramic tile over vinyl tile msrita Flooring 3 06-16-2011 08:01 AM
New porcelain tile to replace vinyl floor in kitchen PatrickGSR94 Flooring 5 03-03-2011 01:42 PM
Vinyl plank/tile over concrete slab Doxy Flooring 16 08-28-2010 08:10 AM
