Vinyl Tiles Over Tar Adhesive - Flooring - DIY Chatroom Home Improvement Forum
Old 09-17-2013, 10:37 AM   #1
Vinyl tiles over tar adhesive
I had asbestos tiles removed from 6 stairs leading to my basement. There is now a tar adhesive left on the steps. I wanted to put down some peel 'n' stick tiles on the stairs. If I remove the tar with an adhesive remover, will that surface then be suitable for the tiles? Or am I going to have to put down an underlayment over the steps? If I need an underlayment on the steps, do I still need to remove the tar first? Thanks!
zzty00 is offline   Reply With Quote
Old 09-17-2013, 10:55 AM   #2
Rewards Points: 13,296
That tar may also contain asbestos.
Those old tiles were harmless untill you tried to remove them.
Got some pictures of these steps?
Peel and stick tile is one thing I refuse to install for lots of reason, just not a good choice. And I can not imagine using them on stair treads.
Why not just remove the whole tread and replace with solid wood treads?
Old 09-17-2013, 12:57 PM   #3
Well, I don't really know what to believe. The guy at Home Depot told me the tar does not contain asbestos. He said he worked in flooring for 15 years. But I've seen online people saying it does. I had an asbestos company remove the tiles, because they were not in good condition, and I already had them there to take care of some other asbestos material. I'm thinking I will call the asbestos company to see what they have to say.
Wouldn't replacing the whole tread be a difficult project for someone with little experience in this stuff? I was hoping for an easier solution. That's why I was thinking peel n stick... I wouldn't be opposed to painting either. But I need a better surface to paint on.
I attached a photo, hopefully that worked.
Old 09-17-2013, 01:34 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 52
The adhesive generally contained more asbestos than the tile. I surprised that the abatement company didn't remove it.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 09-17-2013, 01:44 PM   #5
I just got off the phone with the asbestos guy. He said I would need to test the mastic to see if it contains asbestos to know for sure. He said basically I have two options. Remove the treads entirely and replace or use a good adhesive to put down vinyl flooring right on top of it. He said do not try using a solvent on the mastic as the wood will then absorb the solvent and create a smell in the house. He said I will not be able to scrape it off. Furthermore, they put down an "encapsulant" down right over it when they were here. So... There is yet another opinion that I've heard. I am wondering if adhesive will truly bond to the mastic...?
Old 09-17-2013, 02:09 PM   #6
Here is a link I found from the Flooring Contractors Association:
https://www.fcica.com/press-room/art...k201d-adhesive
It looks like I'm back to putting an underlayment over top.
Old 09-17-2013, 03:12 PM   #7
Rewards Points: 52
Be careful, that link has a virus attached.
Old 09-17-2013, 09:52 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 290
I agree that ripping the treads and risers would be extreme. You should cover with 1/4" underlayment suitable for the type of covering you decide on. You could even install carpeting.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
olzo55 (10-02-2013)
Old 09-30-2013, 05:16 PM   #9
Merle West
Black Mastic is known to cause cancer. You had bettor have all the safety precautions on the job such as masks, gloves and so on. Also check with the city to see where you can dump the mastic legally.
Merle West is offline   Reply With Quote
Old 10-01-2013, 11:59 AM   #10
Mold!! Let's kill it!
Rewards Points: 2,012
I can tell you without a doubt that some black mastic contains asbestos..... also some brown and yellow does as well. Only way to be sure is to test. Your abatement company should have tested it. Standard practice for us is to test tiles and mastic both, prior to removal. I'd refrain from anything that disolves the stuff. It may be that till you get done fussing over it, it may be easier to just replace the treads and move on.
Old 10-01-2013, 04:55 PM   #11
Rewards Points: 3,418
" Furthermore, they put down an "encapsulant" down right over it when they were here "
If that's the case why not do as JazMan said, and cover the tread and riser with a 1/4 inch underlayment and then install what you want?
Canarywood1 is offline   Reply With Quote
Old 10-01-2013, 08:10 PM   #12
Tileguy
JazMan's Avatar
Rewards Points: 290
I think it's the best choice, obviously.
Heck, it's a wooden substrate, nail/screw some plywood. It's easy and best.
I gotta raise a brow reading all these dire warnings about asbestos and adhesives that may contain any. Some may want us to believe we should wear space suits to even enter a house that has some.
It only has the potential to harm you if you sand it and breath in the dust in a confined space for a long time. Like working in a mineral mine for 40 years. Many have scraped floors containing asbestos many times with no apparent effects. If you had to remove suspected materials, keep it damp and use your head.
I'm not recommending anyone do anything they don't feel confy with. Check the materials for asbestos, or just assume certain products contain asbestos and proceed accordingly.
Jaz
Old 10-02-2013, 08:45 PM   #13
Rewards Points: 195
As Sam said, use the 1/4" plywood recommended for your flooring. Put some newspaper or rosin paper between the black adhesive and the plywood. It prevents having a spot that clicks if the ply grabs and releases on the adhesive between fasteners.
olzo55 is offline   Reply With Quote
Help! Vinyl tiles over linoleum mess Tatka75 Flooring 11 11-03-2012 08:27 PM
Vinyl Plank flooring over VAT tiles in basement? jdtox Flooring 5 10-16-2012 08:21 AM
Removing self stick vinyl tiles from vinyl flooring mahobbs1 Flooring 2 07-14-2012 04:39 PM
Commercial vinyl tiles Red Squirrel Flooring 13 02-01-2012 10:08 PM
Help with vinyl tiles in bathroom BethM Flooring 4 01-29-2012 02:50 PM
