Vinyl Tiles Over Pre-existing Layers - Flooring - DIY Chatroom Home Improvement Forum
Old 09-05-2006, 09:58 AM   #1
Question
Vinyl Tiles over pre-existing layers
Hello I have a question i hope someone can help with. We have a room in our apartment that has Vinyl Tiles over some old tiles that im not sure what material is is. The old stuff is on there pretty solid, and so are most of the vinyl tiles on top. We dont want to go to the hassle of pulling up the Vinyl tiles. Not to mention the possiblity of damageing the tiles underneath to lay some Vinyl planks on top. Any one have any suggestions and tips on getting our new stuff down with minimal hassle of the old stuff. If this was our house i houl already be pulling out the tiles or putting on a new plywood subfloor or something. But that is all a bit much for a rental. Thank you for any help you can give.
Thwiipp is offline   Reply With Quote
Old 09-05-2006, 01:10 PM   #2
Building inspector
inspects's Avatar
You will probably wish you had if there is loose material, you are going to be creating another problem if it's not done right in the first place.
Installing new tiles over any loose material is a waste of time and money.
If it was mine, I would have it all removed and installed correctly.
Follow the manufacturers installation instructions, I doubt overlay is an option.
inspects is offline   Reply With Quote
Tiles over existing vinyl Work is good Flooring 3 07-11-2007 10:10 PM
Installing 'peal and stick' vinyl squares on top of existing .... alexz Flooring 8 02-17-2007 04:20 PM
Bathroom Tiling - On top of existing tiles??? moggiex Painting 8 12-13-2006 05:17 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
