Vinyl Tile Perimeter - Flooring - DIY Chatroom Home Improvement Forum
Old 02-27-2014, 01:58 PM   #1
Vinyl tile perimeter
I just installed vinyl tile I my kitchen. At the perimeter the tiles come flush with the baseboards (with an occasional gap up to 1/8). Should I caulk the connection and the gap between the boards and the tiles? If yes, what caulk should I use, can I use acrylic door/window sealant? Do I absolutely have to install shoe molding or quarter round?
I appreciate your suggestions.
BER7777 is offline   Reply With Quote
Old 02-27-2014, 03:13 PM   #2
Rewards Points: 13,734
Need the 1/4 round to do it right.
BER7777 (02-28-2014)
Old 02-27-2014, 06:00 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 388
If you wanna do the job right, and look right too;
you absolutely have to install shoe molding or quarter round.
The vinyl tiles should not touch the base moldings. Be sure to nail the shoe moldings to the base and not downwards thru the vinyl.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
Old 02-28-2014, 08:32 AM   #4
Thank you for your comment. I will add a molding. Now how about this part where the tile borders with the carpet? The edge of the carpet is under aluminum gripper. How should I connect the tile ant the gripper?
Old 02-28-2014, 10:12 AM   #5
Tileguy
JazMan's Avatar
Rewards Points: 388
The tile goes under the gripper. So, you loosen the gripper then tile, reinstall or replace the gripper, re stretch the carpet etc.
Jaz
Old 02-28-2014, 10:33 AM   #6
The tile is already down. It is flush with the gripper. Should I remove the whole row of tile and cut a new row - under the grip, or can I place a carpet strip and cover the connections?
Old 02-28-2014, 11:07 AM   #7
Tileguy
JazMan's Avatar
Rewards Points: 388
Either way. If you replace the gripper you'll lose about an inch of carpet and will need to re stretch etc. Does the gripper look like this or?
http://www.google.com/url?sa=i&rct=j...93581443491Jaz
Jaz
Old 02-28-2014, 12:03 PM   #8
Yes, exactly like that, I think maybe a little less high. I really don't want to replace the new tile. Do you think this homedepot.com/p/TrafficMASTER-Silver-Fluted-72-in-x-2-in-Carpet-Trim-18565/100179121 on top of the gripper will work? Also, how should I anchor the strip nails (my subfloor is concrete)?
Old 02-28-2014, 12:30 PM   #9
Tileguy
JazMan's Avatar
Rewards Points: 388
What do you mean 'on top' of the gripper? The new gripper bar is not on top of the old one. Use concrete nails. You'll probably want 5/8 - 3/4".
Jaz
Old 02-28-2014, 01:06 PM   #10
Something like that:
Old 02-28-2014, 01:34 PM   #11
Tileguy
JazMan's Avatar
Rewards Points: 388
So instead of looking at 3/4" of gripper you're willing to install a regular flat 'applied after' carpet bar which will have to be 2.5 - 3" wide? It's not gonna fit right and look worse.
Ok with me, it's your place.
Jaz
Old 02-28-2014, 03:13 PM   #12
Tileguy
JazMan's Avatar
Rewards Points: 388
What makes you think the flat bar would fit the way you drew it?
I looked at the pics you posted at the other site where you asked.......
=BER7777Maybe I should cover the transition with a piece of carpet trim? (like this one)
http://www.homedepot.com/p/TrafficMA...8565/100179121
Or maybe not................
Jaz
Replacing Vinyl Kitchen Tile connor016 Flooring 2 03-19-2013 11:56 AM
Vinyl on Vinyl on Tile on Concrete blau808 Flooring 2 03-15-2013 10:55 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 01:46 PM
Vinyl sheet tile install - remove or level ceramic? Craigkapo Tiling, ceramics, marble 3 01-21-2012 01:13 AM
