Vinyl Tile Over Luan? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-08-2006, 07:44 AM   #1
Vinyl tile over luan?
Hi! I pulled up the sheet vinyl in my kitchen and rather than cleaning up all the glue w/ paper attached, I scraped the loose stuff and laid Luan over it, making sure to leave a very slight gap in seams for expansion. Also made sure luan seams were different from 1/4 plywood subfloor seams. So what I have now is luan screwed in tight at the seams and screwed every 4 inches thru out each piece, on top of some sheet vinyl paper backing and adhesive, on top of 1/4" plywood. I lightly sanded the luan seams and am getting ready to apply floor leveler over all screw heads and seams. After all this work, I read the manufacturers recommendations and they say do not install the tile over luan. The product is Congoleum Duraceramic, which is a vinyl tile. I really don't want to pull the luan up if it will work fine and hold up, but don't want to lay a floor that will be coming apart next year. What should I do? Also, if going w/ luan is ok, should I seal it w/ something since it is a kitchen? Would sealing it create problems w/ tile adhesion? Thanks for any and all advice!!!
irishghandi is offline   Reply With Quote
Old 03-08-2006, 03:46 PM   #2
Floorwizard's Avatar
Luan is not an approved substrate for alot of manufacturers. (kind of)
some problems are not warrantied.
Home Depot sells tons of the stuff.
keeps me real busy with replacements
Floorwizard is offline   Reply With Quote
Threshold between tile and vinyl tzibello Flooring 1 06-30-2007 09:42 AM
tile on vinyl floor. jkbitner416 Remodeling 6 01-23-2007 07:46 PM
Tile over vinyl hmc Flooring 7 10-26-2005 12:05 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
