Vinyl Tile Adhesive - Flooring - DIY Chatroom Home Improvement Forum
Old 10-06-2012, 02:48 PM   #1
Vinyl Tile adhesive
What is the best way to remove vinyl tile glue on wood floors so that they can be sanded and refinished?
jeksj is offline   Reply With Quote
Old 10-06-2012, 02:55 PM   #2
DIY staff
Rewards Points: 7,174
What color adhesive? How old ?
If the adhesive is black and looks like tar---scrape it off with a paint scraper---that is cut back--and may contain some asbestos--
Extra care must be taken when sanding that also.
Let us know---
jeksj (10-06-2012)
Old 10-06-2012, 03:33 PM   #3
Rewards Points: 6,034
If it's not the black stuff, they make adhesive removers. Depending on what is will probably determine how well it works, in my opinion worth a try.
The Following User Says Thank You to ToolSeeker For This Useful Post:
jeksj (10-06-2012)
Old 10-06-2012, 04:04 PM   #4
It is a glue like substance (kind of like tree sap) with some black that looks like tar. I have half of the tiles up so far - will a sander be able to get off the adhesive or will I have to get that off first prior to sanding? Thanks so much for responding!!
Old 10-06-2012, 04:48 PM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
Do not sand the black adhesive. It probably contains asbestos.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
ToolSeeker (10-06-2012)
vinyl floor tile adhesive residue removal thunderhead Flooring 5 12-05-2011 10:47 AM
Will mortar stick to vinyl tile adhesive on a cement basement floor? samik Building & Construction 6 10-16-2011 03:47 PM
Does this adhesive HAVE to come out before tile? PatrickGSR94 Flooring 14 03-09-2011 07:48 AM
New porcelain tile to replace vinyl floor in kitchen PatrickGSR94 Flooring 5 03-03-2011 01:42 PM
Transition from grouted vinyl tile to carpet MI-Roger Flooring 2 11-29-2009 12:55 PM
