Vinyl Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 01-09-2010, 09:53 PM   #1
vinyl tile
recently put down this 12" by 12" self adhesive tile from home depot. the self adhesive didnt look like it would stick well so i used a primer that they sold for those tiles and the next day i layed the glue they sell for vinyl tiles. the glue dried and layed the tile when it was tacky it looked fine the first day but now i see some corners and edges are sticking up. is there a solution to this problem? should i carfully remove those tiles and put more glue?
ps .... forgot to mention that i didnt trowel the glue but rolled it on. i have a feeling that has something to do with it. but again some areas look fine.
thanks
handekaps is offline   Reply With Quote
Old 01-09-2010, 10:01 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 12
If you must put those cheap crappy tiles down, you should use vinyl tile adhesive, not primer.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 01-09-2010, 10:18 PM   #3
yea i used the vinyl glue adhesive but i rolled it on didnt trowel it on.
thanks
Transition from grouted vinyl tile to carpet MI-Roger Flooring 2 11-29-2009 01:55 PM
Should I use tile or vinyl Quadfam4 Tiling, ceramics, marble 3 04-30-2009 11:58 AM
Vinyl Tile bailey46 Flooring 6 03-01-2009 04:04 PM
vinyl sheet or tile (or allure) over old vinyl? thomase Flooring 8 06-30-2008 06:15 PM
