Old 02-26-2009, 07:40 PM   #1
Vinyl Tile
Hey guys in the process of redoing a kitchen that currently has vinyl tile layed over underlay. The Vinyl tile is being replaced with newer Vinyl tile getting the tile off is a pain but i've managed to get it off, the vinyl tile seems to of left a tacky residue on the underlay. My question is will this be okay to lay the tile directly over, if not how should I go about removing the tackyness?
bailey46 is offline   Reply With Quote
Old 02-27-2009, 06:50 AM   #2
Remodeling Contractor
Vinyl Tile
Replace the underlayment is the best bet. Quicker, cheaper in the long run and will get better results.
Old 02-27-2009, 01:17 PM   #3
Vinyl Tile
You can skim coat it with a portland base cement like Ardex Feather Finish to encapsulate the tackyness
mike costello is offline   Reply With Quote
Old 02-27-2009, 01:34 PM   #4
Vinyl Tile
yes that is good to fix the tacky floor, but will you then have a good surface for installing new vinyl tile?
Old 02-27-2009, 02:58 PM   #5
Tileguy
JazMan's Avatar
Vinyl Tile
Bailey,
You didn't pose any concerns over the condition of the old underlayment, only that it's sticky. Sticky is not a problem. If the floor is as flat as your kitchen table, go ahead and install the new tiles.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 02-27-2009, 05:46 PM   #6
Vinyl Tile
Yes thats what Ardex is made for. Its a flooring specific feather finish. It will also fill small voids, its the stuff I use to flash the plywood seams with
Old 03-01-2009, 04:04 PM   #7
Vinyl Tile
Alright thanks guys, yeah there is nothing at all wrong with the underlayment just that its tacky from the old tiles,
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 49 Yesterday 02:04 PM
Encapsulating old asbestos vinyl tile Familypro40 Flooring 17 03-22-2009 04:20 PM
Vinyl Tile Over Hardwood LGrey Flooring 1 02-16-2009 11:34 AM
vinyl sheet or tile (or allure) over old vinyl? thomase Flooring 8 06-30-2008 06:15 PM
Vinyl tile over luan? irishghandi Flooring 1 03-08-2006 03:46 PM
