Vinyl Squares Over Vinyl? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-03-2012, 07:26 PM   #1
vinyl squares over vinyl?
I have an old kitchen floor that has the large roll type vinyl floor. I need to replace it and was wondering if I could lay the 18"x18" vinyl tiles on top of the existing vinyl. I was trying to avoid pulling up the old vinyl. I was thinking of just putting some plywood over the old vinyl. Would either method work?
brewer362 is offline   Reply With Quote
Old 03-03-2012, 08:58 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
As long as it's a wood subfloor. Plywood over the vinyl would be fine.
Nailing Luan
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 03-03-2012, 11:24 PM   #3
Rewards Points: 182
Originally Posted by RhodesHardwood View Post
Yes you can just stick them to the existing vinyl.
Any pattern in the old vinyl will show through. You would also need to get all grease, wax etc, off the old vinyl and use a primer. And then they may not stick.
Beginner decide Laminate vs vinyl squares in 10x28 backyard cabin? tdg8934 Flooring 3 12-15-2008 05:51 AM
Installing 'peal and stick' vinyl squares on top of existing .... alexz Flooring 8 02-17-2007 04:20 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
